Question about NEC MultiSync LCD2010 20.1" LCD Monitor
Trying to add a multisync lcd 2010 xtraview monitor as a second monitor to my docking station
5 Suggested Answers
informatica
  • 1114 Answers
SOURCE: mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
Rifaa
  • 99 Answers
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
PaulRepair
  • 66 Answers
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 02, 2009
  • 208 Answers
SOURCE: Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Posted on Sep 02, 2009
My screen goes dark when I use my laptop. I have a docking station with monitor and the machine works fine. However when I undock or start up with just the laptop the screen goes black. I can still see...
Hi wilhejl,
I see that you are experiencing a video issue with you back light on this case,
you mentioned when docked on your docking station you see the video on you monitor but when undocked you get a black LCD screen and see shadows of what is on the LCD screen.
this is a back light issue that you are experiencing.
We can try and check some settings regarding this concern and se if there is anything we can do to correct what you are experiencing with your laptop
As soon as you turn your Laptop on keep on tapping F1 to will bring you to the BIOS screen if the BIOS shows up on you LCD screen without going black then most probably yo may need to change some settings in windows regarding the the LCD and power options.
  • Try docking back into your docking station and inside windows go to power options, and set your system power options to balanced.
  • On your Desktop right click anywhere on an open space to get the menu list click on personalize then click on display then click on advance settings, look for screen refresh rate change it to 59Hrtz then undock from your docking station and try booting into windows without using the docking station to check if the video will show on the LCD again on this issue.
I hope that this can help regarding your case,
Have a nice day.
Apr 07, 2011 | Dell Latitude E5400 Laptop
Screen is blank; can not see image with computer on
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys
Additional Information
Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both).
STEP: Determine if an external monitor is being used.
Determine if an external monitor is connected to the docking station.
STEP: Determine if the video problem occurs outside of the docking station.
View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station.
STEP: Remove Any Docking Stations or Port Replicators From the Computer
STEP: Unplug All Accessories From the Laptop Computer
Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Apr 23, 2009 | Computers & Internet
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Inspiron 600m,"no input signal check video cable"?
Do you have an external monitor for use when the laptop is on the docking station? If so, does your laptops screen come on when it's not docked?
If you're using an external monitor while the laptop is docked, make sure that the screen selection is for external monitors, by pressing/hold the FN key and then press the F8 key to cycle through the choices between LCD, Monitor/LCD or Monitor only.
Mar 10, 2009 | Dell Inspiron 600M Notebook
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Dell FP1905FP Stopped working
First try on another computer just to see if there is any other problem then the LCD. Also check power supply to the monitor. I believe this has one that's internal, but if external, swap with a similar specs one. If internal, check to see if any popped up capacitors. Video boards are most likely ok.
Apr 23, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Lg monitor won't come on
Try connecting the LG monitor to the VGA port on the HP tablet instead on the docking station.
Aug 06, 2007 | LG L1920P 19" LCD Monitor
NEC MultiSync LCD2010 20.1" LCD Monitor Logo
55 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
