Question about Maytag Sovereign 60 Side by Side Refrigerator
The ice dispenser flap doesn't open when you press the button for ice. The ice system produces ice ok and the button pressing makes the device drop ice into the chute but the flap at the end of the chute, just before the glass doesn't open. Should it operate by weight of ice (perhaps it sticks a little or should it open with an electronic signal ?
  • robert_batst Mar 22, 2011
    thx. checked flap & there are 2 plastic link strips which appear to be intact. must be the switch then - any ideas on how to fault find it ?
    Champion:
  • 202 Answers
A switch open,s it probably out or something broke on the hinge door plastic junk all of them
Posted on Mar 16, 2011
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
LG LSC26905 makes ice, but will not dispense through door. Ice backs up on inside of freezer door when attempting to dispense ice (crushed and whole cubes). Water dispenses OK. Any help? Thanks.
Sounds like the flap or door directly above where the cup would be is not opening. Press lever and look up in there, if that is the case there is a problem inside the door.
Sep 17, 2011 | LG LSC26905 Side by Side Refrigerator
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
GE Profile 2006 Icemaker (icemaker model: wr30x....) doesn't make ice but cycles perfectly when jumped. Making 8 ice cubes at a time by jumping is cumbersome however. Can you explain how to get the...
The flexible arm is the on off switch to the timer. And the timer is in the ice maker itself. Make sure that arm is in the correct position.
Sep 13, 2010 | Refrigerators
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
Always crushes ice
This was easy to solve after reading some posts which mention "a plastic flap" which is opened or partially closed by the metal rod running under the ice cube tray.
There is indeed a flap which is inside the front of the removable ice holder/dispenser. The flap should be able to open fully so ice can fall out. In mine it could only move 1/2 inch because the flap was laying on the wrong side of a small peg which guides it.
I was unable to free the flap to open completely by pressing on it, so I had to unscrewed six screws to take off the front plastic facing and the on the front plastic housing. Pushing on the metal rod immediately put the flap back into it's correct position. I then replaced the plastic front.
I can now have either whole cubes or crushed. Boy was that easy to fix!
A repairman recommended replacing the electronics ! !
I assume this misalignment might be caused by too much pressure when the ice cubes freeze solid or something? If it happens again, I know it's easy to fix.
Nov 06, 2006 | Kenmore 55692 / 55694 Side by Side...
Maytag Sovereign 60 Side by Side Refrigerator Logo
253 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
