Question about Dometic 57915531 Air Conditioner
Compressor shuts down 59516.531G
The compressor shuts down and won't start again for approximately 30 minutes. I have checked the freeze sensor which seems to be fine and working. If I plug the thermostat into the second port on the control box all seems to run OK but will not cycle.
any suggestions?
  • 64 Answers
Is the compressor too hot to touch when it shuts down? This would indicate a low charge
Posted on Aug 02, 2008
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
My compressor shuts off after a few minutes
Hello
One possibilty is the out side coils or condenser is dirty.And the unit is shutting down on high heat.
Try cleaning the outside coils with some simple green cleaner or even comet spray, then rinse with a hose.
May 27, 2010 | Frigidaire FAS296R2A Air Conditioner
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
99 Ford Superduty Air Conditioner quits working after 10-15 min.
i have an f250 diesel. Same thing, shuts off after about 10 minutes and comes on when it feels like it. Its not the cycling switch. I checked the voltage at the compressor clutch and its 12v. I also, made a "new" ground for the compressor. The black wire at the compressor is ground. This didn't do anything, nor did checking the freon. It will also shut off if you have run it for a while, turn the HVAC selector to off and back on. Although it has power at the clutch (compressor) it didn't come back on.. this is weird.. i think. I was sitting there trying to figure it out and used my test like to "nudge" the clutch on the compressor.. gave it a little "push start" and it came on again.. seems it needs a new compressor? I will see what happens this weekend when i try that. Also, the pressure and contamination switches, are open circuits, that closed and predetermined settings, they are not tied into the ground of the compressor, but "looped" thru the circuit.
Jul 27, 2009 | 1999 Ford F150 Regular Cab
Have a g-23b cratcho granita machine, both sides start up after
if it freezes, the thickness of the mix triggers the torque switch to turn the compressor off. if it doesn't freeze all the way, the overload on the compressor triggers it to shut off to save the compressor from damage. it overloads if it gets too hot or the pressure is too high (also due to heat). make sure the condenser coils on the left side are clean and free of dust and obstructions, and make sure the fan is working to cool it down.
Apr 26, 2009 | Grindmaster Crathco granita machine, 2...
1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Feb 01, 2009 | 1991 Jeep Cherokee Briarwood
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Dometic 57915531 Air Conditioner Logo
222 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
