Question about Samsung VP-D361 Mini DV Digital Camcorder
Can i connect my vp-361 direct to a usb port ?there is a cable where it need a special connection to the pc
Hi Willy, i have the same problem. Im trying to connect my Samsung VP-D361 Mini DV Digital Camcorder to my laptop (Windows 7) but I cant. Is the problem with the O.S driver compatibility?
Posted on Mar 29, 2011
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
I have a samsung VP-D70 camcorder and I want to transfer data to my laptop. The DV out on the camcorder is descibed as 4 pin the other end of the cable supplied is not usb (it has 723 on the connector).I...
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
Jan 16, 2011 | Samsung VP-D70 Mini DV Digital Camcorder
Hi, i m having Samsung VP L850 camcorder. I just want to know, how can i connect it with my Laptop. I also want to buy new battery for it. In Delhi from where i can purchase it?
you may have received a USB cable alongwith the camcoder, look for a slot on the camcoder to connect the cable and the other end on the USB port of your laptop:)
you can visit Nehru Place to buy a new battery for your camcoder
Oct 17, 2010 | Samsung VP-L800U Hi-8 Analog Camcorder
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
Samsung VP-D361
looks like you need a new camera
Aug 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
How to put music on it
First, install Nokia PC suite software which can be downloaded here: http://www.nokiausa.com/A4986252
After installation, you can start communication between the phone and the computer through either cable (special cable connecting the phone to USB port) or bluetooth port. You need a USB dongle attached to your computer if you use bluetooth. The special cable can be purchased from Nokia website.
The Nokia PC suite allows you to input files directly to your phone's memory or SD card from the computer. The Music Player or Media Player in your phone can play the music files. It supports both Midi and MP3 files.
Aug 09, 2008 | Nokia 6126 Cellular Phone
Com port missing?
check to see if the computer even has a serial port, most today dont have them and use USB instead. if this is the case, contact the receiver company to see if the have a usb version of the connection cable and software and download it and the manual for it. check to see if it needs a special cable as well while on the site. it might not need a special cable but it disent hurt to make sure.
Aug 04, 2008 | PC Connection Computers & Internet
Samsung VP-D361 Mini DV Digital Camcorder Logo
548 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
