Question about Systemax Tiger (SYXS-DC-1000) PC Desktop
I was cleaning me pc and forget what way the 2 fan go inside one blowing in and the outside is blow in to and my friend is telling me that the one on the outside sould be blow out not in what way do i place the fans
    Problem Solver:
  • 14 Answers
If the fan is located in the side or front of the computer, it should blow in. If it's located in the back, it blows outward.
Posted on Mar 16, 2011
    Genius:
  • 1,043 Answers
The best way to orient your fans, if you have one if the front and one in the back, is to have the front fan drawing in the air, and the back fan blowing it out. This way you will draw in the cooler air from the outside, let it go across your components, and then the back fan will draw it back outside. This way the air will go across your motherboard faster. If you think about putting your hand outside when you are in the car, the faster you go, the cooler the air feels. Your power supply will already have a fan blowing hotter air out the back of your computer, so you don't want to draw in that hotter air and run it across your motherboard components as they will get even warmer.
    Scholar:
  • 80 Answers
Generally the purpose of a chassis fan on a desktop is to cool the machine. If there was only one fan it should be blowing out. If you have 2 fans then at least one should be blowing out.
(Assuming that the second fan that is blowing in is not allowing dust into the chassis of the computer.)
Hope this helps
Outside AC unit not blowing - Goodman dk-36-1d
1. check to make sure your 220volts is there at disconnect box.
2. check if you 24volts at contactor at the outside unit.
3. if you got it all check the capacitor.
Aug 05, 2012 | Goodman CKL36AR36 Air Conditioner
Old 30 + year old trane. Fan in front. Coils in back. Should the fan be spinning clockwise or counte? I assume it blows air out the front, pulling air pass the coils. Also have to push fan to start. Assume...
It should pull through the coil and blow out the front. The best way to find out is look at the coil. Is there dirt on the inside of the coil or the outside? If there is dirt on the inside, it tells you its been blowing through the coil. If there is dirt outside the coil it tells you its been pulling through the coil. Generally, pulling through the coil gives more square inches of air passage across the coil. Hope this helps.
Sep 13, 2011 | Heating & Cooling
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
Fan over works or slows down and stops completely, i am not pc friendly,still new to this,
Disconnect all cables from the PC and take it outside. Remove the side panel. Blow all the dust from the unit with compressed air. Pay special attention to the cooling fans and the heat sink on the processor. Do not touch any components inside the PC without first touching the outside of the case to discharge any static electricity. Check to make sure the fan on the processor is securely in place. This should solve the problem. You need to do this every 6 months.
Nov 02, 2009 | HP Compaq Presario SR2150NX PC Desktop
UNIT WONT BLOW COLD AIR
The A-Coil is pluged up. you need some foamagator. it will foam up and clean your coils. don't forget to clean the outside coils also. but the one that is stopping the air from blowing is inside by the furnace. Hope this was helpfull
Saw
Aug 09, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Systemax Tiger (SYXS-DC-1000) PC Desktop Logo
71 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
