Question about Watches
The 2 handsets are fully charged and the displays are in perfect working order, but there is no dial tone. There appears to be no reception from the reception icon. What should I do? I can't find my paperwork for this, which I bought in the summer of 2009, so not even 2 years ago. Thanks!
    Sergeant:
  • 302 Answers
Try another phone to be sure the connection is working properly, if good then go on line and look for the instructions for you phone.
Posted on Mar 16, 2011
Hello, please could you advise me? I've bought an Ingersoll ladies' diamond watch for 30 pounds from Cash Converters and I need to have the battery replaced to see if it's working. It has a screw back
I would suggest taking your watch in to a local jeweller. They should be able to replace the battery for a few pounds or give you an opinion on other options. A Google search should find several in your area.
Jan 13, 2015 | Watches
How do I recover the display? The battery is OK
Well if the cell is fully charged, you should be able to touch the reset point inside the watch to reset display. If. Cell has to be replaced, theyre around $20
Oct 09, 2014 | Casio Moon Phase Tide Graph Sport W753D1AV...
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
Stem is broken watch cannot be wound
An Eco-Drive does not need to be wound. It has a rechargeable battery in it that is recharged by light hitting the dial of the watch.
All Eco-Drives have to be allowed to get light on them to recharge the battery. If they are put in a drawer or covered all the time by shirt sleeves then the battery will drain and they will not work.
If the battery is completely drained then the battery will not be any good and will need replacing by a qualified watchmaker.
Try setting your watch under a light or in a sunny spot with the light shining on the dial. If in the sun light it should take a few hours to charge the battery. If under a light it can take more than 18 hours to fully charge the battery.
But if the charging does not hold then the battery is no longer good and requires replacement by a qualified watchmaker.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 09, 2010 | Citizen Eco Drive Largo AT0424 59E Gents...
I want to set the analog time on my casio watch. I read manual but when I do what it says handsetting options don't pop up.
Keep pressing the "mode" button until "HS" appears in the digital display. Then use the right side buttons to adjust the hands.
If this does not work, go to "timex.com" find your support telephone number and give them a ring.
Mar 15, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Fossil ladies 2-tone watch with blue dial
vinegar and bicarbinate of soda will work perfectly
Aug 15, 2009 | Watches
Instructions were for a different fully analog model. The major problem aside from the digital settings, is the mechanical setting of the hands. Even after pulling crown out to position 3, the hands won't...
Tag Multigraph: With the crown pushed in you turn the winder quickly a couple of times and the digital displays appear. Scroll through to the function you want then pull the crown out and turn it to change time/settings. The time can be changed either by pulling the crown out on the T setting (digital) or when no digital display is shown on the dial. If you turn the winder slowly the time/settings change very slowly, which is barely visible. If you flick the winder round very quickly the settings leap forward faster.
Aug 05, 2009 | Tag Heuer 2000 Classic Multigraph...
Blank screen
if this is the same as my watch, it's solar powered and when it gets TOO LOW< it will blank out and begin to charge .  Stick it in direct sunlight for a day if you can.  You can also stick it under a regualr lamp, but it will never get fully charged, but it should be enough to operate at least.  The battery meter is the top middle dial on the face.
Nov 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
23 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
