Question about Acer NSK8458AN Keyboard
HI I have a Acer Aspire something got spilt on it. I have cleaned it with the proper stuff for laptops but the plastic retainer keys some are stuck down or the keys do not work properly is there somewhere that I can buy a bundle of the replacements retainer keys?
    Scholar:
  • 172 Answers
I advise you to buy whole keypad from any site like (amazon) or from local vendor..It will not cost more than $12(i believe.)
Find a link below for more details
http://www.amazon.com/Acer-Aspire-1400-1600-Keyboard/dp/B000MQSX3S
Thanks
Posted on Mar 16, 2011
    Guru:
  • 767 Answers
    Scholar:
  • 155 Answers
I recommend you not wasting to much time and buying a used one on ebay (I can see several available for less then $20).
The replacement process is quite easy and you will save you a big headache.
regards
Keys 5, 6, r, t, f, g, v don't work on Aspire 4720z. What should I do?
1.Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.
2.Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.
3Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
4.Set the key back onto the plastic clip. Push the key down until it clicks into place.
5.Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.
6.Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.
7.Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.
8.Reassemble the keyboard, LED indicator strip and battery.
Sep 28, 2011 | Acer Aspire 4520-5582 Notebook
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
Some liquid was spilt on the key board an the side of my acer aspire one notebook, how do i disasemble and clean it so i can get it back to working, or is that even possible?
You can remove the keyboard and clean any liquid under it. ( The keyboard is one-piece ... and you may not be able to clean easily under each key.)
Review the first few steps to "upgrade the RAM" ... it describes how to remove the keyboard... http://forums.redflagdeals.com/acer-aspire-one-upgrades-how-609546/
Check out the series of pictures (at least the 1st 3) and accompanying instructions to do this ... http://s344.photobucket.com/albums/p322/bb320/
Aug 11, 2010 | Acer Aspire One PC Notebook
I have an acer aspire 5517 model spilt a beer in it,now of course some of the key are really sticky,when i try to enter my passwod i get several letters appearing with one key push,how do i remove keyboard...
Here you go: http://support.acer.com/acerpanam/Manuals/acer/2009/ServiceGuides/SG_Aspire_5517_09172009.pdf
You may want to just replace the keyboard since they only cost in the $30 range. Do a google search on acer aspire 5517 keyboard.
The beer might have gotten into the motherboard which could be a real problem. Good luck.
Aug 07, 2010 | Acer Aspire 5602WLMI Notebook
Tomato sauce spilt on acer netbook keyboard.some keys really sticking down.sauce gone under some keys.
It would be better if you call the Acer technical support no and get it repaired before your mainboard gets fried.
May 31, 2010 | Acer Aspire One PC Notebook
Cleaning the key bored
pop down to pc world and buy anew one is what i would do but for the time being if windows xp go on start menu go to accesability and select on screen key bored.
May 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
Distorted Sound on Laptop after drink was spilt
try to open up your keyboard and try to clean some part of of your keyboard maybe grounded
Mar 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Reattach Acer Aspire laptop Key?
they just clip on.put key back in place and push down firmly.you may have to wiggle it a bit back an forth.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
I spilt my drink on my laptop keyboard...
you can pull the keys out of their sockets and wipe the rubber and plastic holders with a wet cloth. but be very carefull to cloth should not leak, just be wet to dissolve and absorbe the sugar and other stuff that stick the keys. then just insert the keys in the sockets
Nov 25, 2007 | Acer NSK8458AN Keyboard
Acer NSK8458AN Keyboard Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
