Question about Dishwashers
I have the bosh she4apuc/06 It starts the cycle, any cycle fine but in 5 min it will stop and says clean, I have no blockage for the drain if I unplug it from the sink and place the hose in a bucket and it does fine. there is no plug after that either a screwdriver can go through the hole and you can see come through in the sink. but as soon as I put the hose back in to the sink it will not drain and errors.
elhomspam
  • 58 Answers
SOURCE: Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
Posted on May 02, 2008
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
bugsy33
  • 33 Answers
SOURCE: bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Posted on Dec 05, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosh dishwasher SHU43C05UC won't
Welcome to FixYa.
Based on your description " won\'t finish the cycle. won\'t drain and keeps running for ever when gets to 1 min left.Hoses checked and not clogged. I was able to drain the water by doing the test run and punching the rinse and hold button"
I'd say the issue is most likely with the control...unfortunately. The "1" being displayed is actually an error code associated with a heating fault.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, and it does apply to yours....based on just the model number, but check the serial number. It applies to serial numbers betweenFD7905 - FD8505 The issue was directly related to the heating circuit (specifically the heat relay on the control) Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be contacting Bosch re: the recall or calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further. I would recommend you contact Bosch regarding this recall, perhaps the repair will be free...but I don't speak for them.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 15, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch shu3307uc pumps out all the water at the
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch SHU3307UC dishwasher, correct ? Firther to this you.ve stated "slowly fills the bottom between cycles, even with little or no activity at the sink"
It sounds to me like the fill valve is at fault unfortunately. This is a very common problem for Bosch dishwashers of that era.
A faulty fill valve...sticking in the "open" position either due to the plunger in the coil getting stuck or sediment inside the valve body impeding it from closing correctly...Either way you're safer to change it with the history of these valves failing.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance. Thanks for choosing FixYa and good luck.
Please take a moment to rate the assistance provided here and a brief testimony on your experience here at FixYa is appreciated as well and tell your friends to look for "Macmarkus" on FixYa should they need asistance as well.
Regards,
Macmarkus :)
Posted on Sep 27, 2011
Testimonial: "The fix was easy and exactly as described, and works perfectly! Thank you very much! If you need any car advice, look me up, I will be glad to help! Bob"
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
My washing machine is stopping in the middle of its cycle the door locks and the light blinks I tried cleaning out the pump and it started working and then it stopped again
check for drain pipe blockages ours was stopping, i put hose out window and it worked fine so I cleaned out the drain and all ok now.
May 16, 2013 | Washing Machines
My 3 year old front loader suddenly stopped draining, spinning, and now the door will not unlock. It still has power and you can hear clicking, it does cycle through wash, but stops at drain and lights...
This looks like the pump is blocked or drain or the pump has gone. to try and solve it best thing to do is open pump filter usually on bottom front of machine to access pump water will come out so be ready. when you have opened the filter you can check for a blockage and give it a clean put filter back on and put it on a cycle and see if it drains. to make door open start a cycle stop it after a few seconds of being on and turn off machine on machine not at plug and leave it for a while it should open. if it does not then switch off for 5 mins and back on and repeat it hope this helps.
Sep 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Stops at drain cycle and continually beeps have unpluged for 5 min, no help
I had the same problem. I did the following.
- unpluged washer
- drain washer
- tilt back washer on wall.
- The problem was coins, and dryed soap in drain hose.
- You can un-clamp hose without tools using for fingers.
- Pull hose off.
- If there is a blockage this may be your problem too.
- Clean with shop vac and needle nose pliers.
- Re-connect hose.
- Your done
Apr 29, 2010 | Fisher Paykel EcoSmart GWL15
Bosh shu43c never stops running.
If you have a Bosch shu4300...check this site.
http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/
My issue was a heater fault and fixed the problem by resoldering a bad joint. Works fine once this was fixed.
Nov 24, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
