Question about McCulloch Garden
Broken fuel line inside gas tank to fuel filter
  • Kelly
    Kelly Mar 16, 2011
    What is your model AND serial number please? The fuel line itself is sold by PN or in bulk and you can purchase bulk fuel like at most any lawn mower repair shop. With a model and serial number I can find you the exact replacement part. We normally cut the old fuel line under the fuel tank and use a piece or wire or a scribe to fish the fuel line and filter out of the tank. You must thread the new line from the bottom of the tank far enough to install the fuel pick up tube / assembly then pull it back down until there is about 3 to 3.5 inches remaining in the tank and then cut the bulk fuel line to the proper length so that you can attach it to the carb fuel manifold.
    Kelly
  • McCulloch Master
  • 2,239 Answers
If it is micro bore hose it is not so easy, however, remove the filler cap, using a pair of long nose pliers pull any hose left out, take a new hose, cut one end off at a angle appprox 1" long, as this will now be smaller than the hole in the tank, feed it into the top of the tank as far as you can get it to go in, now using the long nose pliers through the filler hole, grab the hose and pull it through.
Posted on Mar 16, 2011
Poulanproleafblower not primeing
Either your fuel is broken inside the tank or your carb is blocked up inside. Empty the fuel tank and look inside and see if you fuel inlet line has a little plastic or metal filter on the end. *(this is called a "clunk") The clunk keeps the fuel line in gas no matter which way you have the blower tilted. Chances are you will see the clunk just laying in the bottom of the tank with whats left of the fuel line still attached. If the fuel line and clunk are intact then your need to get a diagram of the carb and do a dissembly and cleaning. The carbs have tiny screen filters which jam up with debris and gelled fuel. So a rebuild kit with new filter would be a good thing to get if your carb is cruddy. You can look online at Poulanpro and see which kit you need to buy. They are 10-15 bucks usually. New fuel lines is also a good idea if you are going this deep into the unit. Be safe and good luck!
Aug 25, 2014 | Poulan Pro Gas BlowerVacuum ()
Craftsman Gas Powered Blower Mode 358.794772: Fuel lines broken and need replacement. Have new parts from Sears. One fuel line goes to the carb and connects to the fuel filter inside the fuel tank The...
A special fuel filter must be on the end of the fuel lines going into the tank, the line should be long enough for the filter to move around by gravity to stay in the fuel as the tank empties.
Sep 13, 2013 | managemylife.com
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
How do I replace a broker fuel line? The one broken has a filter inside the tank.
Hi doug c197...
I will also include a fuel routing drawing.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Please take time to rate me
Sep 24, 2011 | Garden
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
Fuel input line with filter in the gas tank on four stroke trimmer is broken. If you feed the new line in how to you attach the filter inside the small tank. Cannot see any way to fish the line out thru...
It can be frustrating at times but not as hard as it looks. Cut the line on an angle and feed it into the hole in the tank ( should be a VERY snug fit or it will leak). Using a set of long hemostats reach in and pull the end of the line through the filler cap. Cut the line sraight and attatch the fuel filter and insert it into the tank. Then pull the fuel line back out of the tank till you have the proper amount in tank and filter lays nicely on the bottom. Then cut fuel line to length for proper fit to carb.
Nov 28, 2009 | Troy Garden
Have ryobi 35 head, does not get gas, everything ok. someone said that the gas tank has a filter clogged or line broken. primer seems to be pulling air.
If you are pulling air and you don't get enough fuel, the filter in the tank may either one that is weighted and is just placed on the end of the fuel line. Or it could be one that is attached to the tank with a nipple sticking through and held in place with a ring around the fuel line and pressed up tight to the tank, over the nipple. There is also the possibility that your fuel line is broken somewhere. If you cannot see the break, it would be inside the tank. Good luck,,,Lee
Oct 07, 2009 | Garden
Won't run right
have you checked the tiny stainner at the end of one of the fuel lines inside the fuel tank.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Plastic line to filter disintegrated from heat....
Hi, dont know too much about craftsman, I think it's part of Sears so your strimmer will be badge enginered, if it has two fuel lines my guess is it's japanese, fuel line is available at your dealer or local home base store, if the fuel lines just enter the tank through holes try to get rubber pipe, it seals better, although a clear pipe would be better for the return pipe, thats the one that just pokes into the tank, it's perpose is to return fuel to the tank after priming the carb, to ascertain which is which place your finger over each nipple on the carb in turn as you press the primer button, one will **** on your finger and connects to the filter the other blows and is the return, the return pipe only has to just enter the tank, thats all. hope this helps. a new tank will cost a small fortune if it's japanese. hope this helps. regards Tony (England UK)
Aug 31, 2009 | Craftsman 25cc Gas Line Trimmer
Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
May 23, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
