Microwave Ovens Logo
Posted on Mar 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to purchase a 9 cup corningware purcolator coffee pot
Anonymous
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Mar 16, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
205
Questions
0
Helped
82811
Points
630
Click the link below:
Corningware coffee pot
Be CAREFULL they were recalled. See the information at the site below.
Corningware coffee pot recall
Good Luck.
Zeppelinx12
I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
Use approx. 1/2 cup of coffee to 10 cups of coffee....so for a full pot use 1-1/2 cups... then adjust to taste..
heatman101
1helpful
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Keurig say "brewing" but nothing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
2answers
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
I recently purchased a 4-cup Farberware coffee pot (to replace one that served me well for over 30 years!!) The Model number is FCP with the initial G a few spaces after the FCP. I have had trouble...
Helen,
Fixya is does not sell parts or service, but rather helps answer questions about getting parts and service problems resolved.
You should contact the Farberware website for a replacement cord for your Coffee Pot. Click the "Customer Service" button on the left side of the page, or telephone 1-800-233-9054 for customer service if you'd prefer to speak with someone instead.
I hope this helps - and Happy Thanksgiving to you, too!
Plastic ring is broken inside coffee pot - replacement lid or complete pot is needed for 12 cup barrista unit. Thanks.
I read in a web blog that Starbucks will send you the needed parts (for free) for the coffee pot if you contact them and let them know what your problem is. Here's their site:
http://www.starbucks.com/customer-service
Good luck, and hope this helps.
How much vinergar do put in a 12 cup coffee maker when cleaning it
Howdy, 1 part vinegar to 3 parts water. Pretend you are making a pot of coffee. It is recommended to do this every 2 months or so, more oftenif you have really hard water.
Regards,
Farmerbear at FixYa.com
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
