Question about Odyssey Superspot Followspot W/Tripod (Enx) System
Problem with the odyssey super spot can you help?
GSI Spotting Scope Manual?,"T" camera adapter? availability?
have a look on ebay, type in t2 under (camera > telescope-binoculars) look for a t-mount similar to the picture added. these t-mounts allow for the focus to be adjusted and the eye piece to remain in place. hope this helps87ec49f6-6cfc-43d9-b599-49b2897eaa42.jpg
Jun 16, 2013 | GSI Super Quality 20x60-80 Porro Prism...
My 2004 Odyssey at 1000 to 1500 rpm will growl and the tach will fluctuate quickly. If we raise the rpm at higher speeds it does not happen. Local dealer cannot resolve the issue...its driving us...
Try replacing TPS (Throttle Positioning Switch) These are basically a rheostat and after time they develop a wear/hot spot - usually right around highway cruising position. When they develop a hot spot you get hesitations and RPM fluctuations
Feb 24, 2011 | 2005 Honda Odyssey
My 2000 Honda Odyssey EX has intermittent start problems. At least once a week it will not start without being jumped with a portable jumping system; sometimes turning the key to ignition for about 30...
Probably when the dealer is testing it is fine because the problem is intermittent. There may be a dead spot in the starter so when it hits that spot it acts up but other times its not on that spot its fine. Replace your starter and you will probably get rid of the problem.
Mar 20, 2010 | 2000 Honda Odyssey
Drivers seat is tilting back and forth, a bar underneth is broken
it can be a spring that came loose from its spot under the seat look to where it should be or the seat could be back to far and it depends on how old it is if it has just broke down make sure nothing it in the way and the lever id not stuck hope this was helpful:)
Nov 16, 2009 | Odyssey Steel 2 Ball Srt Putter
How do i replace a broken wiper lever on the steering column of my 2002 Honda Odyssey van?
You can try using super glue jell to glue it back together cost's a $1.00 and if you can get two ice cream sticks to go in the place where it is broken you can cut the sticks to fit and glue then on each side of the broken area on the side where you push up or down. this is a temp fix but can work if you do it right. If you can't get a ice cream stick then try to find a piece of plastic tubing and make it about 1/2 long before and after the break and then apply super glue to the plastic and slide it over the lever and push the two broken pieces together and slide the plastic tubing over it and hold it in place for a couple of minutes once it has set up for 1/2 try it to see if it works. if it holds you got it made if not the professional way is to replace the switch assembly. let me know if you need more help. I gave you the back yard way to do it but if you want to replace it post to the e-mail you get and let me know and I will give you detailed information to replace the arm. It requires three tool you may not have but can rent at most auto stores.
Nov 06, 2009 | 2001 Honda Odyssey
Where is the jack? 2005 F250 super duty
look under the hood by the striker bolt for one part and under the back seat for the other
Aug 24, 2009 | 2006 Ford F-250 Super Duty
Honda 2000 odyssey the shifter is in park, but
The gear range switch on the back of the transmission is either bad or out of adjustment. To adjust, try removing the switch and put it in the neutral position (it should click into this spot). Then put the transmission in neutral and reinstall the switch being careful not to let the switch turn at all during re-install. There is a few degrees of adjustment available by turning the switch in either direction as well if it is still off. The car should only start in park or neutral and the reverse lights should only come on when in reverse.
Jul 14, 2009 | 2001 Honda Odyssey
87 people viewed this question
Top Odyssey Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Odyssey Audio Player and Recorder Expert? Answer questions, earn points and help others
