Question about PNY 8800 GTX PCIE 768MB 2X DVI HDTV 575MHZ Graphic Card
Card will not boot OS. Not sure what has defected in the card. How do I diagnose problem?
  • jflans16 Mar 16, 2011
    Computer boots with another card, therefore the problem lies within this videocard that is inoperable, any other suggestions?
  • PNY Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 16, 2011
  • Brian Sullivan
    Brian Sullivan Mar 17, 2011
    Click start control panel administrive tools computer management device manager scroll to display adapters to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers hope this helps
I woke up to this message. What do I do to fix it.
First you must cheek the hard disk is connected properly then if the problem is still there cheek the hard drive sound is normal in opratoin then if it is not cheek the connectors in the laptop like cables
Dec 31, 2017 | Computers & Internet
Boot does not work
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 09, 2014 | Dell OptiPlex GX240 PC Desktop
No OS found on disk
Make sure no other disks are plugged in (USB/CD/DVD), check BIOS for Boot Order, ensure your hard disk is 1st in order. If it still doesn't find the OS then you may have corrupted data, and potentially a defective disk. You can visit the hard disk manufacturer for a test utility for your hard disk and boot from it and scan the drive. It may even fix some errors.
You may also need to boot from an OS disk and select recovery console and run chkdisk /r on your main drive.
Jan 11, 2014 | Microsoft Windows Vista Home Premium with...
Hasee laptop
If you have any removable media plugged into your laptop i.e USB flash drive, CD or DVD disk, your machine might be booting into one of those devices, you should make sure that the machine is booting into your default OS (Operating System) in the boot menu or remove any removable media into your laptop and then try rebooting again.
Hope you find this helpful if not let us know.
Jul 19, 2013 | Computers & Internet
MAKES A CLICKING NOISE UPON START UP BUT WONT START UP .SAYS DISK ERROR.
Disk error hints that you are missing OS (Operating System) such as Windows. Which can be caused by several reasons: defective HD controller, defective hard drive, damaged partition, corrupt MBR, etc.
The clicking noise is an indication, your hard drive is trying to spin the motor to either spin the drive cylinder or to move the head. In can be normal or it can be damaged.
Try booting from Windows CD/DVD or Hiren, then try to access the drive. If you are unable to access the drive after booting from CD/DVD, then try to format it. And if still unsuccessful, then you have defective hard drive and will need to be replaced.
Jun 10, 2010 | Toshiba Satellite M35X-S311 Notebook
Doesn't boot. IR remote working. No boot lights. Remove memory stick, tries to boot. If program on memory stick, can a new one be purchased?
Power down completely and then remove the memory stick. Wait a full 30 to 60 seconds with power off. Power up to start boot process. Pay attention to the screen while booting to note any messages during this time. If the computer fails to boot still - check the drives (floppy, CD and DVD) to be sure none have disks inside - remove any if found. Attempt a warm reboot if possible - otherwise perform a cold / hardware reboot.
If still not booting, access the computer's BIOS and make sure the information on those pages are correct. If in doubt, set any unknown values to "default" or auto detect. Be sure that the bootable hard disk appears in the boot order somewhere - if not the set as the first bootable device.
Once booting successfully into the OS, insert the memory stick and attempt to read the contents. Many applications that ship on memory cards are not bootable - but yours may. Read the info supplied wit the memory card fully to be sure.
If unable to boot the computer, provide the manufacturer's name, model and your OS. Also include the name of the application on the memory card.
Hopefully, you'll have gotten the computer started before needing to write back with more info. I hope his was helpful - and good luck!
Mar 19, 2010 | Computers & Internet
LAPTOP WANTS TO BOOT BUT STOPS
Could be a number of possibilities:
  • video card;
  • driver(s);
  • virus/malware;
  • corrupted OS files;
  • defective sectors in HD.
Initially, pls try booting into "Safe Mode".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | HP Computers & Internet
Xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Apr 02, 2008 | IBM xSeries 346 Server
Os not booting,when trying to insert usb card
it is due to hard ware conflict of that device and other devices in computer . or it may be due to a hard ware eeroe
try that sound card in other computers also . if the same replace it
Jan 22, 2008 | Computers & Internet
PNY 8800 GTX PCIE 768MB 2X DVI HDTV 575MHZ Graphic Card Logo
27 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
