How can I make my loptop wireless, I bought already a Glink wireless-G ADSL GAteway with speed booster, I connect it but sill I cant connect with the internet. ONE MORE WHAT WILL i NEED TO BUY IF i WANT TO USE THE TV AS MY MONITOR. uSING MY LOPTOP tHNK YOU VERY MH
  • 981 Answers
Well, genius; you need to create a question in a category that isn't generic. Pick one for your laptop model, and ask how to go from there. In fact, if there's a sales/help number from your laptop's maker, call it and ask them if they have a WiFi 802.11g option you can just plug in to your particular model once you open it up to where you can slot it. You'd have to buy that WiFi adapter option for your laptop, of course (though not necessarily from them.)
You have choices if they don't have a ready-built add-in too, of course. Just go shopping for 802.11g adapters in your choice of USB, PCMCIA or any other adapter you have open for use on that laptop; you can of course get portable powered USB hubs or USB sockets adapted to PCMCIA if you're stuck for open ports.
Posted on Aug 02, 2008
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a dsl 2w gateway and I am unable to get the wireless light to come on can YOU help me?????????
You didnt mentioned about the model of gateway laptop, you can turn on the wireless by pressing (Fn+F2) together
Sep 06, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Linksys WAG200G doesn't have a green light with the internet.
Try unplugging the WAG200 ADSL Home Gateway, leave it off for a minute, then plug it back in. Sounds too simple, but it works more than half the time.
Apr 14, 2009 | Linksys WAG200G Router
Appreciate any advice on how to set up Linksys Wireless G Router
here's a basic SoHo set-up.
But if your looking for manual, please provide me your e-mail address so that i can e-mail you.
Thanks.
Feb 09, 2009 | Linksys Wireless-G WRTP54G Router
My internet so very solo
if u r using dial up connection then change it with dsl.if u have already dsl and its speed is very slow
then use modem boosters search it from google and install free of cost it can also help u in dial up connection......
Feb 08, 2009 | Gateway Solo 5300 Notebook
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire wireless
By default, a 2wire modem's wireless feature is already turned on. However the wireless light of that will only be on if a device is connected or trying to connect to it.
check wireless settings for your computer as well
Nov 09, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Fix this thing before my 20 oz estwing does......
Below are some links you can check out and see if it would help you make the gaming console connect to the net behind a 2wire adsl gateway.
Nintendo Wii behind a firewall/router:
Port Forwarding on a 2wire gateway:
Nov 06, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Computers & Internet Logo
David Payne
David Payne
