Question about GE Profile Harmony DPGT750EC Electric Dryer
BLOWER MOTOR NOT GETTING UP TO SPEED
My dryer says the blower motor is not getting up to speed. Can you E-mail me the solution?
Thank you.
  • drillandhang Sep 15, 2008
    My dryer is Gas... but as I entered the diagnostic program, it said that the blower is not getting up to speed?
    Please advise what needs to be done.
    Thanks,
    George
    Drillandhang@yahoo.com
2 Suggested Answers
SOURCE: GE Profile Electric Dryer, Blower nt getting up to speed
On all the ones I've seen with this problem, they've needed a new blower motor. Don't take that as the golden answer because even G.E. tech support doesn't know. It could be the control board, but I haven't seen that yet. G.E. always recommends replacing the inlet thermister, which is accessed through a little cover on the back. Good luck & welcome to the wonderful world of complex electronic appliances.
Posted on Jan 28, 2008
  • 54 Answers
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Posted on Jul 04, 2008
Blower motor not always coming on
the blower wheel is attached to the dryer motor if the motor is running the blower is moving unless the shaft end is worn out the blower threads onto the motor shaft
Nov 19, 2013 | GE Profile Harmony DPGT750EC Electric...
98 buick heater stop working
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Dec 14, 2012 | 1998 Buick LeSabre
Sorry its blower
These will help.
Thanks.
Dec 07, 2012 | 2006 Kia Sportage
Heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
Nov 28, 2012 | 1988 Honda Accord 4 Door
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
Diagnosis: "The blower is not up to speed". What does this mean and how do I check or replace it?
Trace the blower motor wires to the inverter board. It clearly states blower on the inverter board. With an Ohm's meter, check yellow/yellow, red/red, and blue. You should have an approximate resistance value of 14. On mine, it was around 15.2 - 14.9. You must take off he top control panel to access the inverter board. Make sure that the blower motor is getting up to speed. Unfortunately, in order to replace the blower motor, you will have to take your unit apart, drum and all.
Nov 13, 2009 | GE Profile Harmony DPGT750EC Electric...
'05 Freestyle Heater/AC blower only works on high(4). How do I get at the switch or blower motor. Everything is plastic! Does anyone have a solution? Thanks, Bob.
here is what my book says:
Blower Motor Speed Control To Remove:
  1. Remove the right lower instrument panel insulator.
  2. Disconnect the electrical connector from the blower motor speed control.
  3. Remove the blower motor speed control mounting screws.
  4. Remove the blower motor speed control.
Jul 06, 2009 | 2005 Ford Freestyle
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
Jan 27, 2008 | GE Profile Harmony DPGT750EC Electric...
Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Dec 03, 2007 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
64 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
