Question about Jenn-Air JBR2086HES Stainless Steel Bottom Freezer Refrigerator
How do I reverse the door and handle on a Jenn-Air stainless steel bottom freezer JBR2086HES refrigerator
5 Suggested Answers
  • 531 Answers
SOURCE: freezer iced up and refrigerator too cold
checkcoldcontrol or you have defrost problem
Posted on Apr 06, 2009
  • 37 Answers
SOURCE: How do I reverse the
Hi, the easiest thing to do is follow the instructions on page 5 of the manual, here is a link if you don't have it
http://shop.amana.com/assets/pdfs/literature/12642722.PDF
Hope that helps
Posted on Aug 10, 2010
MNTECH
  • 1543 Answers
SOURCE: GE GFSL6KEXLS Stainless Steel (2585
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Posted on Nov 28, 2010
heatman101
  • 43501 Answers
SOURCE: Jenn-Air JBR2086HES bottom freezer, is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Refrigerator side freezing
you could have a bad damper,this is located in the fridge section,all it is is a door that opens and closes to let cold air into fridge,sounds like yours is stuck open.remove the bottom kick panel and look for the tech sheet,it will tell you how to put it into diagnostics,the board will open and close,if it doesn't you know it's bad.go here and look at part number 13
http://www.searspartsdirect.com/partsdirect/part-model/JENN-AIR-Parts/Refrigerator-Parts/Model-JBR2086HES/1266/0161000/M0610191/00008?blt=06&prst=&shdMod=
Jul 12, 2012 | Jenn-Air JBR2086HES Stainless Steel Bottom...
The temperature in both the fridge and freezer aren't working . There is power ,but we are not able to cool it down
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Jenn-Air JBR2086HES Stainless Steel Bottom...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Not cooling top and bottom freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 05, 2010 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Refrigerator is warm and freezer is cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 21, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Jenn Air bottom freezer refrigerator not cooling properly,
This may be your compressor. You'll probably need a hard start kit put ont he compressor if it's not still under warranty. I hope this helps you out!
Aug 13, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
JBR2086HES - Jenn-Air
If it was buzzing then click, the click would mean that the thermal overload has activated. This would happen if the compressor is drawing high amperage due to a breakdown of insulation on one of the starter or run windings. What he says is very possible.
Mar 03, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Refrigerator
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Jenn-Air JBR2086HES Stainless Steel Bottom Freezer Refrigerator Logo
32 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
