Question about Zanussi Dishwashers
The dishwasher doesn't seem to be washing the top tray properly and leaves dirt all over everything
  • Zanussi Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 18, 2011
I have a Whirlpool DWH B00 dishwasher and the problem is that it washes really bad. After the dishwasher is done all the dishes are covered with dirt dots. I have tried to hand dish them some before I put...
Hello, Thank You for using FixYa. I will be helping you today.Start by running a bottle of dishwasher magic through it and make sure the drain line is clear.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Whirlpool Washing Machines
Whirlpool model dp8500xxn2 Leaving white film on everything
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Apr 11, 2011 | Whirlpool Dishwashers
I am using the same quality products to wash the dishes as I have done in the past when I used this machine effectively but now--it doesn't seem to clean the dishes and leaves a film and food residue. My...
See part 1 on this parts list and diagram. http://www.partselect.com/MultiModels.aspx?ModelNum=kuds03ft&searchTerm=img_6G53WSWK&RefineSearch=0&imgMfg=Whirlpool
May 17, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
Dishwasher leaves dirt on top rack
Still worth checking for hot water though, stop machine when you know its at a stage where the water is suppose to be hot. Also when the machine is loaded that the top arms are able to spin freely without hitting anything. Also make sure top arm holes have not got any old foo stuck in as this will stop them from spinning properly. Open door during wash and close door then re open to see how far around it has gone. Not as powerful as the bottom arm but shouldnt be that far of.
Apr 29, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Dishwashers
The powder dispenser on my ls 610a dishwasher does not seem to work properly. There is always powder left in the dispenser and the dishes are not always washed properly.
Try to make sure that the path for water isn't blocked to the dispenser. Ours will do that too if we forget to leave some space for the streaming water to hit the little tray.
Dec 23, 2009 | Ariston Technologies LL64WNA Built-in...
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Bottom spray arm not rotating
The arm usually will stop rotateing because there is a obstuction in the arm itself you will need to remove the arm normally unclips (older machine used to scew off)When you have the arm out check all hole top and bottom and open any that are blocked rinse out arm and replace give it a wash and see if there is any improovement,let me know.
Thanks
Feb 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
It is leaving soapy taste on dishes
you are using way to much detergent. and it is probably a stainless steel dishwasher. you should run a cup of vinegar on the top rack face up with nothing else in the dishwasher and no more detergent. run the vinegar in the dishwasher 3 times and then only cover the detergent tray a third of the way when washing the dishes.. do not put any detergent in the prewash slot.
Dec 24, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Soap is not leaving soap dispenser
sounds like your washing dishes without water. baked on dirt!!!! check under sink make sure water supply is on, next look on bottom of d/w inside tub, theres a mushroom shaped float, grab it and push up and downa few times, if its stuck in up position d/w will be tricked into thinkin its already filled with water
Feb 10, 2008 | Kenmore 15522 Built-in Dishwasher
Dishwashers Logo
79 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
