Question about Ingersoll Rand 1111 Model A Knuckle Saver 1/2 Inch Reactionless Pnuematic Ratchet Wrench
Is there any way to increase the torque on the Ingersoll Rand model 1111 knuckle saver?
SOURCE: ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
  • 14 Answers
SOURCE: owners manual
Get on E-Bay and type in a company by the name of "Industrial_ Manuals". They're a real good source for air compressor manuals. John
Posted on Aug 30, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have an Ingersoll Rand
Contact these folks: They should be able to either holp you or tell you where to get your parts.
Central Power Systems & Services
9200 Liberty Drive
Liberty, Missouri 64068-9396
http://www.cpower.com/partsService/parts/partsFinder.aspx
Phone (816) 781-8070
Email: info@cpower.com
Kelly
Posted on Jul 28, 2011
Impact wrench manual
You can download manuals and parts lists from Ingersoll Rand.
Follow this link:
Ingersoll Rand Industrial Technologies On line Publications
Feb 23, 2014 | Ingersoll Rand Air Impact Wrench 1in Dr...
Torque on ahead bolt
the torque must use is 75ftlbs. that is for the air head.
hope can help.
Jan 30, 2014 | Ingersoll Rand - Rand Type - 30...
Need a manual for a Ingersoll Rand Model 111
If you go online to Ingersol Rand, click on air tools. You should be able to find the IR-111 knuckle saver ratchet. Once there you should be able to click on a link that opens up the exploded view of internal parts. Otherwise go to your local air tool repair centre, they can help.
Feb 21, 2012 | Ingersoll Rand 111 The Knuckle Saver 3/8...
I have an Ingersoll Rand 2340L5 and need to know how to have it come on when it gets down to 120 instead of 100
Change the settings on the pressure switch. Brad Brown has a good description of the pressure switch
Nov 22, 2011 | Ingersoll Rand - Rand Type - 30...
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand 1111 Model A Knuckle Saver 1/2 Inch Reactionless Pnuematic Ratchet Wrench Logo
69 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
