Question about Pelonis Oil Heater HO 157
1 yr old heater leaking small amount of oil. Can I repair at home ??
  • 1,420 Answers
If you can clean the spot where oil is leaKing, Apply some two part JB Weld for metal on it and keep the oil away from the repaired spot until it cures.
Posted on Mar 16, 2011
    Brigadier General:
  • 4,736 Answers
Unless you're a welder. I don't think so. In addition, ALL the oil will have to be drained from the heater and then replaced, which could be a real headache. Personally, I wouldn't undertake it as a DIY project, with the expectation of success. Check to make sure, the heaters not still under warranty, as this leak is a manufacturing defect. Unless, you did something to cause the leak.
Hope that helps answer your question,
Very small amount of gas leaked from vent hole on gas valve for my Goodman 50,000 BTU furnace (LP gas) then stopped. What is the vent on the gas valve for?
Hello, peter, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
Let me know, Mike
Sep 27, 2011 | Goodman GMS90703BXA Heater
Oil is leaking from the heater. can it be saved or do i get rid of it
There are some "experts" on here that would tel you it can be repaired. And certainly, the leak could be repaired, but refilling the heater with the correct oil and in the correct amount, is a **** shoot at best. I look at it this way ... If it leaked once, it's going to leak again, in a different place. So, it's really not worth repairing. Get a new one.
Hope this helped you. Please let me know. Thanks.
May 28, 2011 | Lakewood Oil-Filled Electric Radiator...
I have a 6 yr old Pentair Minimax NT heater that just started leaking water. Is it worth it to repair it, or should I just buy a new one?
Buy a new one. I spent $650 beginning of season to replace the manifold that was leaking and now it is broken. Again. Had since new and every year it breaks, sometimes twice. 6 years of dealing with this piece of junk.
Sep 14, 2010 | Pentair Minimax NT Heater
Small leaking from oil and fluids gaskets, do I need repairs
Cars are not supposed to leak.
A small oil leak will eventually make the whole engine slimy.
If you forget to keep putting oil in, a leak can destroy the engine from running out of oil.
You don't have to have it repaired, but if it is an inexpensive repair, I think you should. (Some oil leak repairs require somewhat extensive engine disassembly, and are not cheap...)
Jul 06, 2010 | 2002 Chevrolet Malibu
Will a crack in the shell make the heater leak??
If the metal has cracked, it is only a matter of thime before it starts to leak. I wouldn't use it unless you are home. If it does leak, it can cause the heater to overheat and be a potential fire hazard
Jan 28, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Hot water heater overflow
check the pipes on top for leaks and if non then your water heater is leaking from inside and that cant be repaired / larryyb
Dec 11, 2008 | Heating & Cooling
Open Questions:
Heating & Cooling Logo
162 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
