Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
I read that someone has a problem with F-03 on the display.
I have seen this for the first time on my hotpoint wf860 1600 spin.
I read the manual the only thing I can think of
maybe an unbalanced load in the machine. Albeit the
manual is not clear about this. P21 automatic features
unbalanced load warning.
