Question about Bose Audio Players & Recorders
My daughter does not sleep well. Very noise sensitive even to clicking of clock or refer going. What is best?
    Sergeant:
    Champion:
  • 205 Answers
Try ear plugs at night.
Posted on Mar 16, 2011
How to change fitbit flex device sleep settings to sensitive?
Great question!! Any luck going into settings on your computer to see if there is an option for that?
Jul 26, 2014 | Fitbit Flex, Set of 3 Swappable Wristbands
I put my desktop to sleep and I can not wake it up.
how to fix windows 8.1 freeze, hangs, can't wake up.
Dec 29, 2013 | Computers & Internet
Anyone got any tips for getting a better nights sleep without having to take medication?
Try some of the following tips. It's what I use to help myself feel relaxed and then I can fall asleep easier.
Try going to bed at the same time every night, even on the weekends. The routine is really helpful for your body clock.
Follow the same kind of routine every night ie shower, teeth, reading in bed as this also sends triggers to your mind.
Sleep in a cool room without any background noise.
Feb 20, 2013 | Health & Beauty
How can I avoid cavities?
You can avoid cavities by limiting the amount of beverages and foods that are high in sugar than you usually consume. It can greatly help you maintain a good dental health.
Feb 03, 2013 | Health & Beauty
Hi, I love my Avent SCD510 monitor, but it started acting up today. In the past, when the parent monitor was on, I could hear every move my daughter made. I could also tell that it was on by the white...
Hi there, I had the same problem. My baby monitor used to work fine, and then all of a sudden it wasn't picking up my baby's cries. I used to be able to hear the static in the background, but I couldn't even hear that anymore.If I pressed the "sensitivity" button on the side of the parent unit, I could hear the static and my baby, but after a minute it would shut off. Very frustrating!
It turns out that somehow the sensitivity had been set to low. (Maybe this had something to do with the time I let my baby play with it...) I turned the sensitivity back up to high and it worked fine.
To set the sensitivity, press and hold the sensitivity button (located on the side of the unit) for about one second. There will be a number of blue lights that light up on the front -- the more lights that light up the higher the sensitivity is. (Mine was set at 2 out of 5, not very sensitive.) While the lights are on, press the + button (located on the face of the unit) to increase the sensitivity (or press the - button to decrease it, but that is probably not what you want to do if you are reading this post.) Press + until all 5 blue lights are on, and you'll be at max sensitivity. (You can adjust it later if this is too sensitive, once you find out of this fixes your problem.)
After a minute, your baby monitor will set itself to the sensitivity level that you set. So if the sensitivity level is really low, the monitor will seem to turn "off" after a minute. If it is high, you should still hear some static.
Hope this answer helps someone! I am really glad I don't have to take this unit back, I like it.
Nov 02, 2010 | Philips Avent® Scd510 Dect Baby Monitor
My mic seems to pick up internal noise even when muted
Hi, You can check you the connectios or the mic. remember that the mic is too sensitive, you can adjust it with the nobb on the mic by putting it on o -dB and reduce the highs on your mixer or EQ to reduce hiss sound.
But fisr check the connection properly to see if when muted, is muted properly.
Take care.
Jun 08, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Just says going to sleep
I will assume that you have already try this monitor with other PC nad also try new VGA cable but still getting the same result. Then the problem will be inside the monitor which you will have to open it up and inspect the inside for failed components. Most common failure in the monitors are capacitors in the power supply section, see some pictures here as a guide to what to look for: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
Engine noise on am stations
this was common in the old days, if you realy want to listen to the am radio and you cant stand the static reving sound of your engin you may need resiter spark plugs and wires.
Aug 01, 2009 | 1998 Ford Mustang
How do i disable/desensitize the alarm? It went off 4 times in the middle of the night - only the wind was blowing.It is causing my wife and daughter issues sleeping.
Nissan does not have motion sensitive alarms. Your vehicle has an aftermarket alarm on it. Nissans audible alarms will only go off if you open the doors, trunk/rear lift or hood.
Jul 31, 2009 | Nissan Murano Cars & Trucks
Clock went out and now have a loud clicking sound even with electricty turn off.
Checked the fuse box and found no issue, but switched it on and off. Then replugged in the oven but still got the clicking sounds. However after again repushing the clock reset buttons the clock came back on and clicking stopped.
Jun 01, 2009 | Bosch Kitchen Ranges
90 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
