Question about Ricoh Office Equipment & Supplies
Good Day I have Nashuatec 10515 Afficio and i do have problems accessing the machine software to add a new user after writing the IP in my browser, the admin cannot logon
botaksetan
  • 80 Answers
SOURCE: can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
  • 84 Answers
SOURCE: Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Posted on Apr 22, 2009
WiFiNut
  • 53 Answers
SOURCE: Ip address to access Siemens sb5830
Make sure you are on the same subnst as your router.
Go to:
http://192.168.254.254
login is superuser
password is admin.
Posted on Jul 06, 2009
SOURCE: WBR-1310. No admin logon, only f/w upgrade page
Finally I rolled back the firmware software to 1.01 and it booted. I'd suggest trying that if you havent already!
Cheers!
Posted on Nov 02, 2010
lexamd
SOURCE: I reset my Audiocodes MP202
It's User/User or user/user
Posted on Apr 26, 2012
Clear access control list on a Ricoh copier
you need first to print the printer configuration list, you will see from which to which ip address you may connect. (example from192.168.1.1-192.168.1.13)
then you will set on your laptop or pc some address that is in the range of access control list, also set the printer ip address in the range of access control. than connect them to connect to the machine by and the laptop/pc with a FTP/LAN
(cross)cable or connect them with a network-switch. Then open a web browser on the laptop/pc and in the address bar write the ip address of the printer. it will open the web page of the printer, login with: user name: "admin" and password:"blank" . find the acces control setting and clear them. set them all with zero. (example: 0.0.0.0-0.0.0.0). if you need further help please write a replay.
Oct 17, 2014 | Ricoh Office Equipment & Supplies
How to add a user to scan on the network
open the browser from your computer, type the ip address of the machine,the machine webpage is going to open. look under basic, address book, add contact, you can add users from there.
Dec 21, 2011 | Kyocera Office Equipment & Supplies
Want to block facebook access for all internet users in small business, boss requested. Can't seem to locate any type of access restriction option
good day,
You can block your Facebook or any other sites by using internet lock software
and you can also unlock it by entering the password you created
you can download internet lock here:
http://www.h33t.com/details.php?id=b8628b0bd9b858e237461bee27a925cbf01452a6&hl=%2Binternet+%2Block
Hope this will help
Feb 01, 2011 | Netopia (3347NWG-ENT) Router (3347NWGENT)
There was a problem accessing your account. Please try again in a moment. Error #1
1. Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2. If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do
[Start] > [Run] > cmd > ipconfig
{{write down the IP address, then disconnect from the Internet with}}
ipconfig /release
{{wait a few minutes and then reconnect with}}
ipconfig / renew
{{compare the new IP address to the old to make sure your IP address changed, then try again}}
If you are an office user, try someone else's PC which will have a different IP address.
Jan 27, 2011 | Yahoo Mail
I am not able to access my yahoo account, showing error code#1, please advise.
ipconfig /release
ipconfig / renew
3. Log into Yahoo through a different country's server. I.e. if you usually log into Yahoo via http://login.yahoo.com/ or http://mail.yahoo.com/ then try http://login.korea.yahoo.com/ or http://nz.yahoo.com/
4. Access your Yahoo mailbox via http://wap.oa.yahoo.com/
5. Use a different browser. Use Firefox (free download from mozilla.com) if you normally use IE or Safari.
6. If you have a web accelerator (mostly an affliction of dial-up users) then try turning it off.
7. If you use a proxy server (mostly a corporate user thing) then try turning it off.
Nov 20, 2010 | Yahoo Mail
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
I am getting this error while trying to log on to Yahoo mail There was a problem accessing your account. Please try again in a moment. Error #1 please help
ipconfig /release
ipconfig / renew
Aug 11, 2010 | Yahoo Mail
My computer can't see the router.
you will have to set the ip addess for the computer to see the router and the router to see the computer
log into the router from your web browser
type 10.0.0.1
this should open the user interface
user name - admin
password 1234 or admin
go to add new user
also add new user password
write them both down
add your computers ip address to the router
save and test
if nothing then run your network and internet wizard to give you access
need more help let me know your operating system and model and make of your computer
Thanks Misterdj
Apr 25, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Want to password protect the router
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 28, 2009 | Linksys WRT160N Wireless Router
I cannot access western digital 1000 gb
Here is a tedious solution that works. Use MioNet and move all the files you want to keep to another drive or another computer, then delete everything from the MyBookWorld. Remove MioNet from all computers. Next access the drive's built in Shared Storage Manager with a web browser. Check the pdf manual on the install disk to find out how. Create a new shared folder and then move everything you want on the drive into the new folder WITHOUT using MioNet. Map the shared folder as a network drive for easy access. Never, ever, EVER use MioNet again and all should be good. The drive works, the MioNet software does not.
Feb 19, 2008 | Western Digital 500GB My Book World...
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
