Question about Garden
I have a Honda f210 rotovator the engine run,s o,k but when it touche,s ground the tiller,s stop. colin cullip
rcampsr
  • 90 Answers
SOURCE: Troy Horse tiller engine stalls after warm up under load
Has any work been done on the engine? Especially the carburetor? There is an insulator piece between the engine and carburetor to reduce the heat from the engine. Also the muffler has a screen inside of it, if you have the two piece muffler on the engine that gets plugged up and the motor looses power. There are also two small feed tubes that hang down inside the fuel tank that also get gummed up and they also will cause the same symptoms. Is the motor burning any oil yet? This will happen when the rings get worn out. If the valves get bad the motor will be hard to start due to lower compression. There could possible be a mechanical cause from the cam shaft if it lost oil to it for some reason and caused a lobe to round off, but this would be prevalent at all times. You can put a compression gage on the engine to check the compression by pulling the cord and rotating the engine over three compression cycles to get a reading. Good Luck, RAC
Posted on Apr 18, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: having carburetor problem with honda f210 tiller
I need the year make and model. This sounds like you just need to adjust the idle screw or clean the carb with some carb cleaner and it should be good to go
Posted on May 16, 2009
  • 5 Answers
SOURCE: Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Posted on Sep 06, 2010
  • 150 Answers
SOURCE: honda mini tiller cuts off when start tilling.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Posted on Dec 11, 2010
How do I determine why I can't shut off Honda FR800 tiller; faulty engine stop switch?
Switch just grounds out spark, you may have a wire off. The test is to run a jumper to ground switch and see if it stops or jumper across the switch with a wire and see if it stops
May 14, 2015 | Honda Garden
Pull starter honda f210 rope has come off
remove the starter cover whined the spool in the opposite direction that the rope pulls out hold it into place with a knot on one end feed the other end threw and out threw the opening pull it threw and tie on the pull handle
Aug 18, 2012 | Honda Clutch Cable F200 F210 F260 Tiller
While operating the Honda FG-100 mini tiller, the tiller suddenly stopped turning. The engine runs fine. I couldn't find any advice in the manual. Any help would be greatly appreciated.
If the tines become jamed, the tiller will stop. This is especially true if you are preparing your lawn for seedng without doing an preparation of the ground. Also, check you accerleration line, there may be a loose connecton.. Otherwise, sounds like a service issue.
Aug 28, 2010 | Honda 25cc 4-cycle Mini Tiller
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Having carburetor problem with honda f210 tiller and it won't stay started
May 16, 2009 | Honda Garden
Need new carburetor
I will check to see if I can get you one at a resonable price.
May 07, 2009 | Garden
Honda f210 tiller leaks gas when not running. if you leave the gas valve on it leaks on the floor. if you start it you have to regulate the amount of gas going into it, or it will flood out. it runs rough...
yes that's the problem.float level...you remove the float bowl and bend the float until it is at the factory specs.get you a manual and it will tell you the float height.if it says 4/32 you get you a 4/32 drill bit.put *** under the float chamber and bend until the bottom of the float touches the bit.
Apr 29, 2009 | Garden
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
