Question about Rothenberger 70523 Plumbers Pliers 12"
My main line sack in my house is crack how much thats going to cost for the repair
Plumbing Stack?
You will need a plumber for that
This is a social chat site,we are at
home
Posted on Mar 16, 2011
The city of Sikeston, mo. Can the board of municipal utilities change the responsibility of the sanitary sewer line maintenance?
sewer main to premises means from the main to your boundary as is the case in all councils
the service line is from your house to the connection at the boundary
you can not be held responsible for pipe damage under council or main roads authority
Jan 13, 2018 | Cars & Trucks
City of Sikeston Mo. does the board of municipal utilities can they change ownership of sewer line from the city to property owner ?
I have never heard of that. Since all sewage lines are run in series, If there is a main line issue downstream from where you live, are you and everyone upstream responsible for repairs? I would ask for verification of what rules are in place for upstream and downstream repairs and certification. Also, if they are transferring ownership to property owners, are you free to go out to bid repairs to contractors or are you bound to city/county repairs. Sounds like your being passed the burden and cost of repairs while the city/county is passing all liability to the property owners.
Jan 13, 2018 | Washing Machines
Master 165000 btu heater
pump cracked or main air line can b checked by turning on heater and blowing through the line coming off the back of the heater if u get fuel and flame then start looking for line cracking and or pump cracked on the back of unit pre sprung filter and the main between the plastic and the metal pump housing
Dec 09, 2013 | Heating & Cooling
What is the difference between a stuff sack and a compression sack?
Your sleeping bag is usually sold with a stuff sack, which just refers to the (usually nylon) bag that the sleeping bag comes in. If space in your backpack is not an issue, than the provided stuff sack will be fine for you, but keep in mind that it is not totally waterproof because water can enter in through the opening at the top. A compression sack is a separate sack that you can buy if you want to pack your sleeping bag into a smaller size. The compression sack shrinks the size by allowing you to use straps to squeeze any excess air out of the sleeping bag. The straps are connected to a piece of fabric that can cover the opening of the sack and make it completely water-proof.
Dec 26, 2012 | Camping, Backpacking & Hiking
Can the material seat come off the Uno Peg Perego stroller to be washed?
  • 1
    Unbutton the lining sack from the seat to remove the lining. The buttons are located on the sides of the seat beneath the armrest.
  • 2
    Slip the seat lining off the foot cover. Pull it out from the bottom.
    • 3
      Detach the lining sack from the armrests. Unbutton each corner and pull this part of the lining out. Do the same for the lining on the adjacent armrest.
    • 4
      Pull the bottom part of the safety belt out from under the seat. This will allow that part of the lining to come loose.
    • 5
      Unbutton the side tabs from the backrest. The side tabs are behind the backrest near the armrests.
    • 6
      Slide the tabs off the backrest. The tabs are wrapped around the back side of the backrest and should slide off now that you have loosened everything else. Remove the sack completely from the stroller.
    • 7
      Wash the sack in cold water by hand. Use a mild detergent. Do not wring, use bleach, iron or dry clean. Do not place the seat in the dryer as it may shrink.
      Performance Chip
    May 23, 2012 | Peg Perego UNO Baby Stroller 2008 Bubbles...
    My RCS Scenium TY Bulb Housing gets hot very very hot and smells up the whole house. My Bulb burned out so I went to replace just the bulb (which I have done several time) and the wires insulation was...
    The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
    It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
    Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
    Apr 21, 2017 | RCA Scenium HDLP61W151 61 in. HD-Ready...
    What is the cost to repair Bravia KDL-40XBR9 ? Cracked screen with colored lines
    The screen also known as LCD panel is the most expensive part in an LCD tv. Its cost is usually greater than or equal to the cost of the tv. As much as I hate to say this, the best way forward would be to sell the working parts of the tv(such as power supply board, Main A/V board, Backlight inverter board, T-Con board etc.,) online to save on a new set.
    Aug 15, 2011 | Sony Televison & Video
    I just had it under little magazines to hide it from my siblings and when i got home from my friends house 2 days later the screen was cracked. how much will it cost to get the screen fixed?
    Your best bet will most likely be to replace it with a used unit from eBay, as the unit wasn't particularly designed with field repairs in mind. You can transfer your files over to your replacement unit using an SD card. Bottom line is that it would cost more to repair than it would to repalce it...
    Feb 28, 2011 | PANDIGITAL Digital Book 843967071153...
    Rothenberger 70523 Plumbers Pliers 12" Logo
    397 people viewed this question
    Top Rothenberger Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Rothenberger Plumbing Expert? Answer questions, earn points and help others
