Question about Ovens
RCM10CRK Black Electric Range Cooker has a problem the main oven is runing cold the fan is on but no heat, ps can it be the clock on the oven is playing up
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
SOURCE: Fisher and Paykel electric cooker (Pepper)
There is a combination of 3 buttons you need to push at once. I believe from left to right it is the second and third button together and then the plus button as well
Posted on Apr 11, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
SOURCE: clock on cooker flashing
Excellent! Now my clock works, but where can I get an instruction booklet for this oven? Thanks.
Posted on Jun 10, 2009
barkencoa
  • 3463 Answers
SOURCE: cannon oven not working
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Posted on Jul 19, 2009
Opening oven door trips rcd when up to temp. doesnt do it when cold
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 22, 2011 | Smeg SE290X Stainless Steel Electric...
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 07, 2011 | Smeg Ovens
The fan only blows cold air and does not heat up any food.
Jun 13, 2011 | Smeg SE399X/5 Stainless Steel Electric...
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
48 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
