Hello, I'm trying to repair a 1930 GE Monitor refrigerator.Model DR-1/ Form B.It was working up to yesterday, when i noticed the switch was in the off postion,then i tryed turning it to the on postion and it when in to the off postion again.I then took off the the cover which felt very warm and noticed the coil was orange looking. I'm thinking it might be a capacitor. Please help
  • 981 Answers
Gee, you should put this question in a category about GE Monitors, preferably your exact model in the category; then you can see how things with it were solved before. Or refrigerators, since you put that word in there too. Don't turn it on again until you unplug it and go through to see what's burnt out so far!
Posted on Aug 02, 2008
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
I have a GE monogram refrigerator model ZFSB26DRSS. Yesterday the freezer stop working (set temperature 0F, reading temp 30 F). In the morning the refrigerator got warm too (set temp: 37 F, reading...
This sounds like the compressor is not running. Causes for this happening on your model can be caused by defective start relay, run capacitor, defective fan motor and defective motherboard. The part number for the motherboard is WR55X10942
The repair is rather complex for most people on your model and I will be glad to go through how to do this if you like. Let me know and I will walk you through the repair, Thanks
Sea Breeze
Apr 09, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
I bought mu D-R2 DVR without original remote. Got one GE universal and just set it up and got to the main menu.And this was my 1-st time to get there.Checking settings, I changed from DR-1 to DR-3 and...
hello inira. DR-1 and DR-3 are two separate but similar toshiba model types.
Your machine must offer both in that one machine. Your best bet is to replace the remote with a new original remote control.
here is a link where you can purchase one
http://www.replacementremotes.com/
Joe
Apr 29, 2011 | Toshiba D-R2 DVD Recorder
Hello, I have a GE gts18fbrerww refrigerator for about 6 years. Yesterday I started to hear a noise coming out from the freezer. Is the evaporator fan causing the problem? could this be replaced if I...
Good day,
Yes. The motor is the only moving part in the freezer compartment.
Changing it is pretty much a nuts and bolts type repair.
I suggest you also buy a new blade when purchasing the motor.
In rare occasions ice can form around the fan blade causing the problem, so I would remove the rear panel and check for that issue before you buy the motor.
Sep 26, 2010 | Refrigerators
My ice maker stopped working, but the freezer was still working. Yesterday, I noticed some water at the bottom of the freezer, and everything was defrosted. The refrigerator is working fine. My model...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile Artica refrigerator that WAS making ice cubes and quick ice until yesterday. What can I do to get the refrigerator to make ice again? The model # is: PSC 23 NG.
if its just stoped dead it could be a number of things
1 the thermostat give up working,,,most likley!!!!
2 the compresor give up working,,,not very likley
3 its lost its gas and needs a regas,,,pigs fly?
try a new thermostat first,,,
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cooling problem with a ge top freezer refrigerator
I have one that did the same. The coil in the back of the freezer was frosting up because it wasn't defrosting like it was supposed to. I noticed that the thermostat looked damaged so I ordered a new one from sears parts direct which by the way will show a diagram of the model you have. I just installed it last night so I will post how it comes out. This morning the freezer has a burnt smell but I am hoping its from the defrost not working for a while!
Mar 03, 2008 | GE Hotpoint Top-Freezer Refrigerator
Water button not work
You can check the site again on how I fixed the same problem. GE also has a recall on many refg. with this same problem. Probly a frozen line inside dr.Quickest way to isolate is to disconnect line at were it enters bottom of dr. and press dispenser tab. If you have water to this point it is about 99% sure a freeze in dr. No water means probly selenoid or the switch or something else. Ice and water line do not feed off same line , ice will dispense even if water does not.
Dec 24, 2007 | GE GSH25JFR Side by Side Refrigerator
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
