Question about HP Computers & Internet
Llohr@kent.edu OWNER: Lucille Lohr Hi. Last night, when I turn my monitor on, the orange light (for the monitor's "ON" button) turned blue (as it should, indicating it is turning on). Then, the "Windows" box popped up, and then a white box immediately popped up saying "Monitor going to sleep". ??????? I've connected and disconnected all of the wires tried re-installing the original start-up CD, and have tryed everything I can think of to figure out this problem myself, but I've been unsuccessful. Please help!!! I'm contacting you from my computer at my job, so if I haven't heard back from you by 5:00pm this, I won't see your message until tomorrow. Please help me - I'm a single (and VERY POOR) working mother putting myself through college, and I'm very dependent on my computer for my school work. So, basically, my monitor is perpetually in "Sleep" mode, and I can't get it back into regular working mode. Thank you so much! Lucy Lohr
Kimi
  • 277 Answers
SOURCE: Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Posted on Nov 20, 2005
  • 749 Answers
SOURCE: Monitor going to sleep at startup
It seems that the computer itself has a problem... Try to remove the memory, clean the contact points and insert them back, do that to other components like the video card, modem card, sound card... Try also to change the CMOS battery, I change my battery every year, sometimes this is the culprit. So I hope this helps....
Keep us posted if it doesn't work. Have a nice day.
Posted on Aug 27, 2008
  • 124 Answers
You most likely have a hardware failure.
Your video card or on-board video in the computer is probably dead.
Posted on Jun 08, 2009
SOURCE: LG Flatron L1932TQ won't turn on
I have the exact same problem. Just like Ptepe, I also found the 680uf/25v and 1000uf/16v capacitors in positions c203 and c204 on the Power Supply PCB to be bulging on the top. I considered replacing all of the electrolytic capacitors on the board, but decided to just try the visibly effected ones first. Please make note that the instructions provided below are to be followed at your own risk! Soldering on a delicate printed circuit board will be required for this repair and the board can be permanently damaged if done incorrectly, not to mention the potential for bodily harm! If you have warranty, you will obviously want to pursue that avenue first.
1) Remove the monitor's base by removing the plastic cover over the connectors and then the one over the base's bracket and unscrewing the four screws. While you're in the area, there are two screws, one on either side of the bracket, that must be removed. They are in the recessed wells.
2) Turn the monitor upside down so the narrow edge is facing you. You will see at either end of the bottom edge an arrow pointing toward a slot. Side a small flat head screwdriver under the cover in the direction of the arrow. With the screwdriver still inserted, unclip the bezel by pulling the plastic in the direction of the arrow. Repeat on the other side and carefully pry the rest of the clip points loose all the way around the screen, while carefully holding pressure against the screen so it doesn't fall out, and the plastic bezel will come off. Be sure to unscrew the switch assembly from the bottom. There are two screws.
3) Lay the monitor face-down on a soft, clean surface like a folded blanket. There will be five screws on the back with the fifth one in the center. Remove all of these screws and very gently lift the plastic cover away, making sure to keep the screen from falling out abruptly.
4) With the back of the screen and electronics exposed, you will see a sheet metal case with a few wires routing from it to three points on the monitor and the switch assembly. To the left you will see a metal cover held in by one small screw on the narrow edge. Remove this small screw and partially remove any tape that may be securing it. You may replace the tape later if it loses adhesion. Remove it, gently lifting the metal case where it overlaps the cover.
5) Next, partially remove any tape that is securing the wiring harnesses (it can be completely removed if you are planning to replace it). This will give the metal case a sufficient range of motion to allow you to lift it up on the right edge and expose the large harness routed to the top of the screen. This harness has a bit of tape covering the connector at which it terminates, and the tape must be lifted to expose the connector. Gently remove the connector straight out of the socket. Avoid diagonal movement as much as possible.
6) With the large connector removed, the metal case can now be flipped over, with the screen remaining flat, to expose the circuit boards it houses. On the left is the processor board, on the right (the one with the big capacitors) is the power supply board. First, remove the black plastic cover over the power supply board. This may require some flexing of the plastic and/or clips. Be sure to make sure any wires attached to it are detached. Next remove the small metal slide panels covering the upper and lower wiring harness connectors on the case (the ones routed to the upper and lower parts of the monitor on the left side). With the two upper and two lower connectors exposed, note their positions and disconnect them.
7) Now the case is completely disconnected from the monitor. Carefully remove the connector from the board on the right that connects to the board on the left. Unscrew the four bolts holding in the power supply board (the lower left screw is larger than the others). Carefully lift the board out, angling the side with the power connector downward. Be very careful not to touch components on the circuit board.
8) By comparison, you may clearly see which capacitors are bulging on the top. These are the ones you want to replace. If mine and Ptepe's experiences are consistent with yours, you will see two out of a cluster of six larger capacitors with bulging tops (the cluster is on the opposite side of the really big capacitor and the two common capacitors are surrounded by the others). While you have the board out anyway, check for continuity through the fuse with a Digital Multimeter and check for any visible defects such as burn marks or melted solder points.
9) Very carefully desolder the effected capacitors. Verify their rating (most likely one 680uf/25v and one 1000uf/16v capacitor) and order them. If you'd like to replace all of the medium capacitors, it couldn't hurt. You can even replace the really big one if you want, but make sure you measure everything...including height, width and terminal spacing. For the ones that I used, though, they're 10mm x 20mm radial aluminum electrolytic capacitors with 5mm terminal spacing and 105C temperature rating.
10) Solder in the new capacitors, clip the excess pin lengths and reassemble in reverse order. It may take some finesse to put everything back the way you found it, but if you paid attention while you were taking it apart, it shouldn't be too hard (and taking pictures with your camera phone along the way can help too).
This solution worked for me. If it wasn't for shipping, I would have paid $1.18 for the entire repair. If you can find it, the power board can be replaced as an assembly, too, if you screw it up. :) Good luck!
Posted on Jan 05, 2010
Keynan
  • 977 Answers
SOURCE: My HP w2007 monitor is
From my experience, it probably means that there's a problem with the COMPUTER, rather than the monitor... Please follow my tips here.
Regards,
Pelu.
Posted on Oct 18, 2010
Hp Desktop wont turn on
You have to restore OS to original factory status. May be pressing F10, F2, F11 or F12 while PC is starting, then follow instructions on screen.
Jul 04, 2013 | Computers & Internet
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
We have rolled out Dell Optiplex 790 machines running Win XP and using E2210 monitors. Recently networking applied power managment options to power of the monitors in 20 mins of inactivity. The monitor...
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Sep 13, 2017 | Dell E2210 22" Widescreen Flat Panel...
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Aug 21, 2010 | Proview PL926WBi 19" LCD Monitor
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
My LCD Samsung Sync Master 172x Blank Screeen
Hi Yanss1971,
May i know, what's the power led light status? Red, Green, Orange, Blinking or Off? If you need more info on lcd monitor repair please visit this site as reference: http://fastrepairguide.com/p/lcd-monitor-repair/
kent
May 09, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Flashing Lights
means you need to get it check out by a technician
Sep 28, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
