Motor Voltage error displays on my Roland cx 24 vinyl cutter.
  • Anonymous Oct 12, 2008
    motor voltage marca mi roland cx-24 cuando lo enciendo, me podrian ayudar o tengo ke llevarlo con un tecnico??
    raulporras36@hotmail.com
  • Emmanuel Sep 28, 2017
    Hola lo pudiste resolver? Que es ese error? Gracias
    New Friend:
Posted on Sep 28, 2013
  • yash Sep 28, 2013
POWER SUPPLY BROKEN
Posted on Feb 13, 2009
Roland Camm-1 CX-24 Error Er15:RS-232Err How do I fix this? Thanks John
Could you let us know when this error pops up. and what all you have tried
Thanks
proton
Aug 02, 2008 | Computers & Internet
Fault motor voltage error
Check the voltage. You may have to do a hookup. (hookup) a unique connection to a component to check voltage or signals.
May 09, 2014 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Pen mode light blinking
Material not aligned or wrong thickness... Blinking means something is not right. Try taking the material out and see if it changes, things like that, troubleshooting....
Nov 26, 2013 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Convert igp to pcl for kyocera printers
Sep 28, 2013 | Kyocera FS-C5015N Laser Printer
Message error moteur (02) sur camm 1 GX 300
XEROX 5020 PHOTOCOPIEUSE ERREUR U4 LA SOLUTION
Sep 16, 2012 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
Hi, we have a roland camm-1 cutter plotter. It has been showing "fan error" on the display these last few days but would correct itself when turned off and on again. Now though,when I put vinyl in and send...
I had a similar problem. The issue was that I would receive a "fan error" notice but the fan was still spinning when the error displayed and then the machine would stop. I took plotter to my garage, removed the covers and used my air compressor to blow out the dust from the fan and the circuit boards. When I blew out the fan, a ton of dust and "dots" from the punched material came flying out. After a thorough cleaning, I put it back together and have not had the problem since - it works like new. I think what happens is that the fan becomes clogged with dust and dots and slows the fan enough to send an error signal to the plotter. No dust, no dots, no error! Try that - hope it works for you!
Sep 16, 2010 | Computers & Internet
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
1,478 people viewed this question
k24674
jasbo
jasbo
