Question about Whirlpool LEW0050P Electric Dryer
I am having trouble connecting the hose to the dryer vent I did not receive a "Coupling" as described in the owner's manual, and I cannot identify the Coupling on the Whirlpool parts website. Without a Coupling, I cannot vent my brand new dryer.
  • 344 Answers
Greetings ehielema,
I will try to help you to my full ability. I have a few suggestions for you.
1. If the manual states that a coupling is supposed to be included, I would contact the store where it was purchased and explain the situation.
2. Go to your local home hardware center with your manual and ask an associate for help finding the coupling that fits your model of dryer.
I have taken a large amount of technical training on washers and dryers (among other things). I have found that there is one standard coupling for a dryer vent.
I hope this helps you! Good luck to you and thank you for using FixYa!!
Posted on Aug 02, 2008
  • Wes Sydenstricker
    Wes Sydenstricker Aug 02, 2008
    Or even better, use the coupling from your old dryer if there is a suitible one.
    Genius:
  • 1,665 Answers
Write your model No at search tab of link below to se available parts
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
    Brigadier General:
  • 3,614 Answers
Use the old coupling that you remove on the older parts
Does this dryer have a reset? It is not heating
Hello, if you've never worked on a dryer, DON'T. The symptom you describe is probably an open heating coil or a blown thermal fuse mounted on the heater box. No, there is no reset of the type you are thinking of...If the dryer is running but not heating, usually the heater coil has a break somewhere along its length and must be replaced. This is an INVOLVED repair! Bosch products are different animals anyway and you must know how to disassemble, troubleshoot, and replace the faulty component(s). Next, after repairing the dryer, you must find the cause of the failure, most likely a kinked or blocked vent hose connected to the unit. Also, the airflow out of the dryer vent(outside your house) must be fairly close to what is coming out of the rear of the dryer with the vent hose disconnected. If it is significantly weaker, you very well might have a blockage in the wall in addition to a blockage in the vent hose.
Aug 13, 2015 | Bosch Dryers
I have an LG Dryer and keep getting a error message D90 after running for about 10 minutes
D90 means the dryer thinks the vent duct is 90% blocked. Be sure the vent hose is not kinked behind the dryer. I've even disconnected the hose from the dryer and hooked up my leaf blower to blow out the vent as it develops more air pressure than the dryer does.
Here's a great video describing the error code: https://youtu.be/yL7Oq4lCadw
Good luck. Hope this helps.
John
Mar 22, 2015 | LG Dryers
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
Our dryer keeps overheating and then shutting off with an e66 service code. we have had a reputable repair man out twice. he replaces numerous parts but then the dryer did the same thing after 4 uses. we...
Instructions
Things You'll Need:
* Owner's manual
* Screwdriver
* Lint bags
Troubleshooting Your Dryer
1. Check the area around the exhaust vent of your dryer. One of the most common causes of dryer problems, including overheating, failing to dry clothes properly and not heating up properly, is that the exhaust has been blocked by dirt, lint, and other debris. In addition, the cheap vent hoses that come with many Electrolux dryers are not adequate for the job, and it is a good idea to replace those vent hoses with higher quality stainless steel replacement hoses. In the meantime, be sure to check the entire length of the vent hose for blockage, removing any kinks as you go.
2. Check the thermal fuse. Many models of Electrolux dryers are equipped with a thermal fuse, and if this thermal fuse is faulty, the dryer may not run at all, or it may run but not generate any heat. Consult your owner's manual for the location of the thermal fuse on your dryer model. On many models, the thermal fuse is located inside the back cover panel; you may need a screwdriver to access this panel. Be sure to unplug the dryer before you get started. If the thermal fuse is blown, be sure to replace it and try to run the dryer again.
3. Check the power cord running to the dryer. If the cord is frayed or damaged it could cause the unit to short out and not run properly. If the cord is damaged, the dryer may run sometimes, but refuse to start at other times. Be sure to check the entire length of the cord, from the point where it attaches to the dryer itself to the point where it plugs into the wall. If the cord is frayed, cut, or damaged it will need to be replaced before you attempt to use the dryer again.
Feb 28, 2011 | Electrolux EIED55H Dryer
Just got a new tumble dryer with built in vent and hose. Trouble is i have a hose and vent already fitted to outlet (wall) in kitchen what can i do? Will i need to take out the whole fitting in the wall....
Take hose off the vent and then stuff plastic into the vent and take some drywall mud and fill the rest of the vent with mud. Doing that will keep criter out of you home
Jul 21, 2010 | Dryers
Brand new vented dryer causing condensation in
Hello, I would recheck the exhaust hose connections, as it sounds as if you've either got some holes in the vent hose/line or the connections are not fully around the dryer exhaust vent, etc.
You might also want to look at the dryer to see if the internal exhaust pipe came loose during transport and installation. It might be possible that the exhaust vent pipe inside the dryer is loose or off the fitting. An easy way to check this is to remove the exhaust pipe from the back of the dryer and (with the dryer unplugged from the electric outlet!) check by looking into the back vent on the dryer. You can also feel inside to see if it's loose, etc. Just be carefull as the metal pipe could have sharp edges, so wear some gloves to be safe.
As this is also a new dryer, you might also contact the place where you purchased it, as there might be an quality issue that they've received a service bulletin on and could provide you with further assistance.
I hope you find this Very Helpful and best regards!
Dec 14, 2009 | Tricity Bendix Dryers
My dryer is only 3 years old and it sometimes lately has like a chemical smell after running a while.. its electric.. any reason for this?
In the years I repaired dryers they do have distinctive odors. But dryers each year should be checked for lint. Proper installation is a must. Most modern homes the dryer has little room to repair the appliance when necessary. Some dryers have metal ductwork making moving the dryer difficult. Now the popular method is with flexible hose usually 4 inches in diameter. This makes the job easier but has a distinct disadvantage. The dryer vent hose must not be installed in such a way that the air flow is restricted. Two 90 degree bends are allowed. Vent hoses over 10 feet (two 90s) can fill up with lint a dangerous condition which left unchanged can clog up the vent and passages in the dryer. Lint around the heating elements will burn this is normal when adequate venting is mantained. Elastic and other rubberized waistbands should not be allowed to overheat see the owner's manual.
Keeping filters clean after each drying cycle is a must. It is a good idea to remove the vent hose or tubing and inspect and clean. You may need a service technician to clean areas you can see but not reach. Nothing wrong with shutting off the power to the dryer and using a vacuum to clean dryer areas.
Nov 17, 2009 | LG DLE2532W Electric Dryer
Whirlpool 3RLEQ8000 Electric Dryer
I'm not sure about this with your machine but look low on your front panal. Most have two screws holding front panal on. Usually hidden in the character line along the base.(Clips will hold the the upper under the top...just flip up the panal it will pop off.) I hope this helps.
Aug 30, 2008 | Dryers
Whirlpool LEW0050P Electric Dryer Logo
109 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
