Can't log on to netbook. lost password - Computers & Internet
  • 27,725 Answers
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
or
Ebay you can purchase a Password Unlock/Recovery For Windows 2000/XP/Vista/7
Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7
Buy It Now price: US $1.49 (Approximately AU $1.50)
also
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem.
http://majorgeeks.com/download.php?det=2969
Save files you specify before shutting down KillCMOS basically "resets" your computer's CMOS settings to the factory defaults. Works with ALL CMOS. KiLLCMOS only changes checksums & values that makes the motherboard CMOS revert back to factory defaults.
Editors Note: We occasionally are informed that programs like KillCMOS are infected with a virus. Note that the operating system system requirement for this program is DOS. This means you need to be able to boot from a floppy or CD to DOS and execute the program. If you are running this program from Windows, then you did not read the directions. Any good anti-virus program will detect an attempt to access the bios and inform you it is a virus.
hope it helps
Posted on Mar 16, 2011
    Novelist:
  • 147 Answers
This solutionwill work only if you have forgotten your Windows password. It will not work if youhave forgotten your boot password or hard drive password etc. Please post back if you need a boot or BIOS password.
Read on if you want to use a USB flash drive. Scroll down if you would ratherburn a CD/DVD.
USB Flash Drive Method
You need to download a Windows passwordcracker, put it on a flash drive, and boot it outside of the Windowsenvironment. This solution will show you how to do that.
1. Download the Ophcrack Windows password cracker from here. For Windows7, click on the ophcrack Vista LiveCD.Ophcrack is one of the best free Windows password recovery tools available.It's fast and easy even for a first time Windows password cracker. Save file toDesktop.
2. Download Xboot 1.0.0.0 Beta 6 here. Savefile to Desktop. Unzip file and extract to Desktop.
3. Plug a USB flash drive into your PC and format it with a FAT32 filesystem. This can be done by opening "My Computer" and right clickingon the USB flash drive and selecting Format. Select FAT32 and click OK. (Note:this will erase all data on your flash drive.)
4. Open Xboot.exe. Select the Ophcrack ISO file you downloaded and drag it ontothe Xboot screen.
5. Click on "Create USB" found in the bottom right hand corner of theXboot window.
6. Select your USB drive and click OK. Wait for your USB flash drive to becreated.
7. Restart computer and press F10 or appropriate function key for your computerto enter the temporary boot menu. It may be F12 or F9 etc. Look at the firstscreen that appears when you turn on the computer and you will see which key topress. You also could enter the BIOS and change the boot order if you wouldprefer that method.
8. Select USB Flash Drivefrom the boot menu.
9. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Modeoption when it appears.
10. Ophcrack will automatically begin cracking your passwords. The longer andmore complicated the password is the longer it will take to crack. 99% ofpasswords are crackable. Any password over 14 characters cannot be cracked.This program found my 8 character password which contains letters and numbersin less than 10 minutes.
11. Write down your password when it's cracked. Remove the USB drive andrestart computer.
Good luck and thanks for using FixYa.
Burn a CD/DVD Method
You need to download a Windows password cracker, burn it to a CD/DVD,and boot it outside of the Windows environment. This solution will show you howto do that.
1. Download the Ophcrack Windows password cracker from here. For Windows 7, click on the ophcrack Vista LiveCD. Ophcrack is one of the best free Windowspassword recovery tools available. It's fast and easy even for a first time Windowspassword cracker. Save file to Desktop.
2. Burn the Ophcrack LiveCD ISO file to a CD/DVD using the Windows 7Disk Image Burner or another burning program. For Windows 7 users, pleasefollow steps 2a and 2b. If you are using Vistaor XP you will need to use a CD/DVD burning program already installed ordownload and install a free program such as the one here.
2a. Right click on the ISO file and select "Open with" and thenselect Windows Disk Image Burner or another CD/DVD burning program.
2b. Put a CD-R or DVD-R into the DVD/CD drive and select Burn. Wait for theburning process to finish.
3. Restart computer and press F10 or appropriate function key for your computerto enter the temporary boot menu. It may be F12 or F9 etc. Look at the firstscreen that appears when you turn on the computer and you will see which key topress. You also could enter the BIOS and change the boot order if you wouldprefer that method. Many computersalready have the CD/DVD drive as the first boot drive so you may not have to dothis step.
4. Select CD/DVD from the boot menu.
5. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Modeoption when it appears.
6. Ophcrack will automatically begin cracking your passwords. The longer andmore complicated the password is the longer it will take to crack. 99% ofpasswords are crackable. Any password over 14 characters cannot be cracked.This program found my 8 character password which contains letters and numbersin less than 10 minutes.
7. Write down your password when it's cracked. Remove the CD/DVD and restartcomputer.
I forgot my password to log onto microsoft windows ce on my netbook and now i can use it at all. How can i recover my password or reset everything?
There are three options that you can follow: Option 1:use password reset disk if you have made one. this is an easy way to reset just follow the instructions. Option 2:use command prompt to reset Windows 7 password, but you should login your Windows as administrator Option 3:use third party program to reset lost windows 7 password.Windows Password Recovery Tool is a good choice that you can try, you can reset the lost password in several minites
May 19, 2014 | Computers & Internet
Booklet log in
To recover lost Windows 7 Starter password, just follow the tutorial:
http://lnkd.in/bBjDVRs
Dec 27, 2013 | Nokia 02718S2 Booklet 3G Netbook PC -...
My admistrator password on my netbook acer aspireone i forgot it
Lost Windows password:
  • Log in as Administrator (try safe mode if you don't see Administrator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Aug 31, 2012 | Acer Aspire One Netbook 8.9" Notebook
How can I reset my sylvania meso netbook if i have lost the password and cannot get into the control panel even by means of the hint?
- Put the operating system CD then perform system restore
I accept donations for my free service Thankshttp://www.paypal.comsend it to paypal email: rpamular10@yahoo.com
Mar 12, 2012 | Sylvania Meso 1.6 Ghz Intel Atom 1 Gb 80gb...
My son changed his password on his netbook. now he doesn't remember it. he cannot log in at all. he can do absolutely nothing with it. how can we fix this?
at Windows XP's Welcome Screen, simply press Ctrl-Alt-Del keys sequence together twice, and you will be shown a Log On to Windows menu where you can specify the User Name and Password. In the User Name text box, key in "Administrator" (without quotes) and leave the Password field blank. Then press Enter or click on OK. If there it is not a password protected Administrator account, or blank password is set, then you will be able to access the Windows with full administrative privileges as Administrator.
Then simply click start > control panel > User accounts then select your sons account and click edit then click remove password. once done simply log off and then log in to your sons account and no password will be asked for. If your son is the root administrator then you will need to get software to reset the password for you
Mar 23, 2011 | Computers & Internet
I recently bought my daughter a Sylvania Netbook....... She can't remember her password to get into her computer.......... How can she/I reset or discontinue using a password to get into...
The only way that I know that will work is for you to re-flash the system, since the password is contained in a file that was loaded on to the machine's nand chip. You would have to erase that total file and the only way is to erase the whole system and reload it from a SD card. see my TIP at:
: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
And please follow the detail exactly.
Feb 09, 2011 | Sylvania G-Netbook
How doe i ulock hp mini 5201 i cant log in forgot password
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Jan 24, 2011 | HP Mini 110-1037NR Netbook
Forgot the password how to log on
A Windows password reset bootable disk could do all the job for you, it can reset your lost or forgotten Windows password safely and quickly without login, you can create a Windows password reset bootable disk with the tool Windows Password Breaker, then use it to reset your password
Dec 26, 2010 | Sylvania G-Netbook
Lost log-in password
what is password? for windows? for BIOS? for what?....
you use eeePC with Linux OS or Microsoft Windows OS? For Linux, follow my instruction for recovery your OS. Press F9, after you turn ON your netbook. And follow that instruction. Or you can use recovery DVD (include your netbook), after you plug in external DVD-ROM and make it boot priority for first is DVD-ROM (enter your BIOS first).
Sep 21, 2009 | ASUS Eee PC 701 Notebook
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
