Question about GE WBVH6240F Front Load Washer
It has a r ed light with a lock on it on how do we get rid of the lock
    Brigadier General:
  • 6,277 Answers
If I am understanding you correctly this is at the end of the spin cycle.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
What words do the letters meridia spell
Aide Rim
Idea Rim
Admire I
Aired Mi
Aid Mire
Aid Rime
Aid Emir
Radii Em
Radii Me
Amid Ire
Maid Ire
Ramie Id
Ear Midi
Era Midi
Are Midi
Aim Ride
Aim Dire
Amir Die
Air Idem
Air Dime
A Die Rim
A Mired I
A Rimed I
A Ride Mi
A Dire Mi
A Id Mire
A Id Rime
A Id Emir
A Midi Re
A Dim Ire
A Mid Ire
Ad Mire I
Ad Rime I
Ad Emir I
Ad Ire Mi
Aide I Mr
Idea I Mr
Dare I Mi
Read I Mi
Dear I Mi
Aid Rem I
Aid Re Mi
Amid Re I
Maid Re I
Raid Em I
Raid Me I
Arid Em I
Arid Me I
Dam Ire I
Mad Ire I
Mare Id I
Ream Id I
Ear Id Mi
Ear Dim I
Ear Mid I
Era Id Mi
Era Dim I
Era Mid I
Are Id Mi
Are Dim I
Are Mid I
Aim Red I
Aim Id Re
Amir Ed I
Air Ed Mi
Air Id Em
Air Id Me
Am Ride I
Am Dire I
Am Id Ire
Ma Ride I
Ma Dire I
Ma Id Ire
Mar Die I
Ram Die I
Arm Die I
A Ed I Rim
A Die I Mr
A Red I Mi
A Id Rem I
A Id Re Mi
A Dim Re I
A Mid Re I
A Rid Em I
A Rid Me I
Ad Re I Mi
Am Id Re I
Ma Id Re I
Feb 23, 2015 | Miscellaneous
Smartlock problems ed fairmont ghia
You need the system scanned for faults.
Oct 31, 2017 | Ford Cars & Trucks
Tried to open door and window does not slide down for access; opened door and tried to start-nothing happens; oil and battery and air bag lights are on....do you know is this is caused by central locking...
Hello,everybody,the good shoping place,the new season approaching, click in. Let's facelift bar!
===== http://www.vipforshopper.com ====
Cheapest Air Jordan Shoes,Tiffany Jewelry Company,Wholesale Hollister Clothing
Air jordan(1-24)shoes $33
UGG BOOT $50
Nike s h o x(R4,NZ,OZ,TL1,TL2,TL3) $33
Handbags(Coach lv fendi d&g) $33
Tshirts (Polo ,ed hardy,lacoste) $16
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $12
New era cap $9
Bikini (Ed hardy,polo) $18
FREE SHIPPING
A friendship founded on business is better than business founded on friendship.
Aug 21, 2011 | 2002 Porsche Boxster
My ed hardy luggage got locked and I wanted to
How do you reset an Ed Hardy hard shell suitcase?
Apr 11, 2010 | Photography
My dishwasher is locked and I don't know how to unlock it. The door opens, but it want start the locked light is on. how do I unlock it?
Hello- Try this: press and hold heated dry button for 5 sec. This should unlock control, and will lock it again if you repeat. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 12, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
The door lock light remained on and the elements won't heat up.
Hello- Sounds like a door switch. If power is shut off and turned on again, lock motor should cycle back to 'open' . If not, one or both switches could be bad. Control boards are rarely the cause of lock light on. Switches are difficult to get to and check. A good tech should have these parts close at hand. If you choose to repair yourself, we can help. Let me know if this info helps- have more if needed- Thanks- ED
Mar 06, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
How do i close applications on the main page on a samsung jet mobile?
Basically to get rid of any reminiscent widgets (like if you were playing music and the widget still is in your desktop), just drag the widget you want to get rid off into the sidebar (the side bar will automatically expand when you drag the widget into it, and your widget will minimize and insert itself into the side bar).
Now the widget is officially closed .
Enjoy :) Ed
Sep 26, 2009 | Samsung Jet S8000 Cell Phone
Brake light on dash won't turn off.
I just had my brakes done (all 4 rotors replaced and brake shoes) on my 99 Camry, and when I took it for a test drive, the Brake light was on. The way I got rid of it was by disconnecting the battery for a minute or 2. It reset whatever was causing it to stay on.
Hope this helps.
Ed
Apr 14, 2009 | Toyota Avalon Cars & Trucks
DOOR LOCK WONT OPEN
do both of you have a digital display? if so are you getting any codes that f- with a number?
Nov 20, 2007 | GE JGRP17 Gas Single Oven
GE WBVH6240F Front Load Washer Logo
14 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
