Question about GE Wireless Optical Mouse
98564 is not working this morning - GE Wireless Optical Mouse
  • 1,381 Answers
Hello smscerbo858
Solution one : press the connect button at the rear of the mouse .
Solution two : replace battery .
solution three : check the usb connection of the receiver and make sure it's placed in a reachable sector for the mouse .
If nothing of this works , the mouse is defective and needs to be replaced .
Best regards ,
fanaudi
Posted on Mar 16, 2011
I have a GE 98564 mini mouse. I look in the row on the lower right & it doesnt even show up. how do I connect it to my laptop to function? the first time I plugged it in the usb it showed, but didnt...
on bottom of mouse the are a switch (black piece as button) press to sync the mouse
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | GE Wireless Optical Mouse
The device is showing up on the device list, but I cannot get the mini-mouse to work. It is GEs 98564 model, any suggestions?
It may sound obvious but have you turned on the mouse? There is a small button on the underside of the mouse that you need to press. The laser will then come on and it will then connect to the USB adaptor.
You may also need to change the battery in the mouse.
Jan 09, 2011 | Computers & Internet
Hello my GE ergonomic wireless mini mouse #98564, connects with my computer sometimes and not others. Currently it will not connect, it has new batteries, dings when the card is inserted into port, but...
I have been fighting with several of these GE Wireless Mice. Pressing the connect buttons on the mouse and USB receiver would not re-connect the mouse. As some ohere posting have pointed out, that little white circle on the usb plug shows where to squeeze to trigger the receiver to re-connect. When you've squeezed correctly, the red LED in the USB pug starts flashing brightly - not a dim flicker. You are supposed to then press the connect buttom under the mouse. Immediately the flashing LED on the receiver should go off, and your mouse should be ready to go. Each time you move the mouse, the same LED in the USB plug should flicker to show activity.
I have tried all this so many times without luck. Even replaced the mouse batteries several times - from the same pack.
Here is my 'FIX'. I think this mouse is very tight on the voltage it needs from the batteries. You need absolutely brand new, full power, good shape batteries. Bateries that look OK in another device, might not work in this mouse.
If you have a test meter and know how to use it, find a couple of batteries that are giving at least 1.6v each - more if possible. Pop these in, do the connect process above, and there is a good chance it will connect up fine.
Good luck.
Oct 20, 2010 | GE Wireless Optical Mouse
New wireless mouse will not connect and move on the screen. GE 98564
You have to press the button underneath the mouse to turn it on. If it is on a red light should show. You must also install the driver that came with the mouse.
Sep 11, 2010 | GE Wireless Optical Mouse
My Bonaire gas ducted central heater works in the afternoon but not in the morning. I have cleaned the filter and in the morning the RESET button appears I have done what the manual explains me to do. But...
sounds like limit sensor has gone bad, or tstst does not shout off periodicly and it shouts down by a safty precaution as to not crack heat exchanger
May 19, 2010 | Heating & Cooling
My 2006 heaer doesn't work
check the coolant level on the radiator..it sounds low
Feb 04, 2009 | 2006 Hyundai Accent
GE Wireless Optical Mouse Logo
356 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
