Question about Ovens
My fan assisted Hotpoint double oven was sparking at the back and now is simply blowing out cold air, but the top oven is still working?
    Champion:
  • 202 Answers
Un plug it and call appliance man b/4 you get fryed
Posted on Mar 16, 2011
I have an ew42 hotpoint electric cooker. the oven fan works but only blows out cold air - so it is not working.
You need to replace the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Nov 23, 2010 | Hotpoint Ovens
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
I have a Korting fan assisted oven, it
It is without doubt the element that has blown.
It is located at the rear of the oven compartment behind a removeable cover.
Hope this helps solve your problem
Dec 14, 2009 | Baumatic B180 Electric Single Oven
Fischer paykel double drawer motor runs constantly and will start
Is it the actual oven fan located on the back wall of the cavity behind the fan shroud or is it the cooling fan which is at the top of the cavity and blows air across the top of the oven? The cooling fan can't actually be seen.
Aug 07, 2009 | Fisher and Paykel AeroTech Double - OD302M...
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Oven doesnt heat up
remove back panel inside oven and element will be exposed. this element is probably faulty and you can often see the damage
to replace, take the outer rear panel off and element fixings are in view - easy job usually
Sep 09, 2008 | Ovens
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
108 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
