Question about Maytag Washing Machines
Maytag washer (Stacked-top loading) is not filling with water. It will go on to spin. It's 5 years old and has never had a problem. Thanks!
    Brigadier General:
  • 6,277 Answers
This is symptomatic of either a malfunctioning water control valve ( failed/no power position is closed and not allowing water feed), poor wiring contact to it or from the control board OR the board itself.
Sorry but I fear the only answer is a service call ;-0(
Good luck,
John C
Posted on Mar 16, 2011
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
Top load stacked washer, won't pull water into machine, just
check hoses are not kinked /filter a the fill hose solonoid valve is clear if valve is okay should work...
Mar 31, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag washer lse7804a won't fill
with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
