Question about BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300 cd/m2 - 700:1 - 5 ms ... LCD Monitor
Hi just bought the benq fp222wa from a friend, but i cant get it to work it blinks for 2 sec "input D-sub" and in the background i see the windows page. and after that its all black and i cant use the menu on the screen its all black
  • 1,915 Answers
This sounds like the power board on the screen is bad. How old is the unit? You might be able to get warranty repair on it.
Posted on Mar 16, 2011
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Apart from the "line input"
input and output are for low level ( as with RCA cable connectors) ,, the speaker connections are for high input, (red and black connections. ) you can run the mains to the (rca) from your receiver to run the sub woofers, and from that use the speaker wire connections, to go to the left right speakers, (out only not in) this is done if you want to run the subs and the Rt/lt/ speakers , eliminating the speaker connections coming from the receiver. which you could use for 2 additional speakers if you want
Apr 23, 2011 | Wharfedale SW150 Subwoofer
3 blinking red standby lights, 2 sec pause, but no TV picture
Hi, shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Mar 28, 2011 | Sony BRAVIA KDL-52XBR6 LCD TV
Benq FP222W
Your monitor must have multiple inputs (Dvi,D-sub) so it searches when you start for which input is connected.
If menu popping up intemittently is your problem,The culprit is generally defective (Leaky) Key switches.You need to pen up monitor and replace.
Normally BenQ has a 3 year warranty.
Dec 28, 2008 | Computers & Internet
Monitor
Look up the BenQ website. http://www.benq.com/support/
These monitors have a 3 year warranty in most cases.
Failing that cantact BenQ directly with the phone numbers on that same site.
Apr 07, 2008 | BenQ T705 17" LCD Monitor
No sound out of woofer
Hello sparkie102
Happy Holidays
you have to check if all the cables are well connected, and in the right inputs. 2) check your software for sound that is enable, fine.
turn up the sub volume , if got it independent.
other that this, is a failure sub. if got warranty, use it! or RMS your sub.
Dec 26, 2007 | Logitech Z-2300 Computer Speakers
Screen working and after 2 sec screen black
On your power board you will have a faulty surface mount fet with 8 legs that controls the backlights.
There are 4 of these, but if any of them fail the protection circuit turns them all off.
Best best is to get it to a local technician for repair. It is not an easy task unless you have the right equipment.
Hope that helps. =)
Dec 14, 2007 | BenQ FP92W LCD Monitor
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Benq fp737 17
How old are the monitors?
Normally backlights last at least 30,000hrs of working.
Normally problems on Inverter board transistors near yellow inverter transformers.
Samir
Nov 28, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP222Wa - Flat panel display - TFT - 22" - widescreen - 1680 x 1050 - 300 cd/m2 - 700:1 - 5 ms ...  LCD Monitor Logo
124 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
