You have not mentioned the manufacturer and the model of the PC. The general answer for this question will be :-
1. to check the maximum memory capacity of the PC
2. In some PC's you have to use 2 identical memory sticks otherwise it would not work.
If not this 2 then 1gb memory stick is bad.
Please re-post this with the manufacturer and the model of the PC so that we can assist you in a better way.
Was this helpfull ?
Please rate this.
The way i see this problem is the 2nd stick that you are refering to is defective or damaged. All you need to do is to bring back the stick into where you bought it then ask for a replacement.
Cheers. . .
the computer is an Emachines t5082 and the max capacity is 2g via 2x 1gb slots. next time i am at computer i will swap out the two one gb chips to see if the one is broken, and will repost the results
