Question about Fujitsu Siemens Televison & Video
Hello. I have a Fujitsu Siemens TV Myrica PDP-TVP PQ 42-1, and it is 5 years old. No problem until today. First did the colours slowly change. After re-starting the colours were ok for a short while, but after a minute the colours started to get weird again. Then after another minute the screen went black (there where one "ticking sound" like when it's shut on/off). After that the screen is black when the tv is started. Is that a complicated problem (expensive), or "just a fuse"? Best Regards, Tobias
  • tobias73 Mar 16, 2011
    Hello.
    Thank You for the response. I can open the tv, I'm just looking which part of the casing that can be removed (standing or laying flat?). I would think it is a power supply issue since we heard a clicking sound from a contactor.
    BR
    Tobias
    Sergeant:
  • 261 Answers
Sounds like to me you either have a video processing problem or you have a powersupply issue. The only way to tell is to open set up and check the powersupply voltages and then go from there.
Let me know if you are willing to open that baby up and then we can check for correct power supply
voltages... Talk to you later. HDTV GURU JAY
Posted on Mar 16, 2011
  • Jay Henderson
    Jay Henderson Mar 17, 2011
    Most voltages are on the boards near the test points. But check around in there and see if anything looks burnt or is running hot. Expecially the powersupply board. Be very careful in there. there are some extremely high voltage in their and you could get shocked... Just don't touch any of the heat sinks while it is running and you should be fine. You will need a volt meter and lay the unit down on its face and remove all screws securing the back panel.. After you get that done, make sure we can plug it in to the wall or get power to it for testing purposes. Once u have that, we are 1/2 way there..Then start checking voltages and write them down on a piece of paper... VCC, VS,VE,VSS ETC. Test all connections to ground and that will give you a good reference to start from.. Let me know what you find and then we can go from there... Good luck .... and be careful. Have a good one.. Sincerely HDTV GURU JAY
Plasma inverter
If you only have half of a picture, usually top or bottom, then there is a problem with the upper or lower scan buffers. What is the make and model number and is it split top to bottom?
Feb 07, 2018 | Fujitsu Siemens Televison & Video
Fujitsu Siemens plasma TV P50 - works ok - the problem is the remote control, always been a problem - bad signal ? it was nessesary to directed very exact towards the TV and not too far away/less than 3 m/...
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
May 13, 2017 | Fujitsu Siemens MYRICA P50-2 50 in. Plasma...
We got a Myrica PQ42-1 that takes the fuse in our house all the time. After 2-3 times it turns on. Is this normal??
I have the same problem. Returned the TV for warranty repair and got it back still with the same problem. "Change your fuses to 16A slow" was the message from FSC service shop. (16A=3500Watts!)
I have mounted a 10A fuse directly 'between the TV and the 230V outlet so the (house) fuse does not drop.
Now my ******* TV went all black, probably the backlight.
Jul 08, 2010 | Fujitsu Siemens MYRICA P50-2 50 in. Plasma...
Black screen on my Fujitsu Siemens Computers Myrica television
sound no picture does it flash when first powered on ? its the invertor board it controls all the lamps
that light the screen/shine torch into screen you
will see picture/needs repaired google{ohm supplies uk}
Apr 18, 2010 | Televison & Video
Flashing red light no screen fujitsu plasma
This is a common complaint with Fujitsu plasma displays with a few years age. It is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Jun 04, 2009 | Fujitsu Plasmavision 42" TV
I HAVE PLASMA TV MYRICA P50-2.
The link below is where you can get the information about how to buy Fujitsu television parts. I have no idea if they will sell to non contracted servicers. These sets are serviced mainly by board swapping. You can eaily buy boards that you think are defective, and they are not the fault. This is the gamble you will be taking when servicing these sets yourself.
http://www.fujitsu-general.com/global/contact/pdp.html
Jerry G.
Jan 31, 2009 | Fujitsu Plasmavision PDS-5001 50 in....
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Turns off after awhile
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Apr 12, 2008 | Fujitsu Plasmavision PDS-4214 42 in....
Televison & Video Logo
648 people viewed this question
Top Fujitsu Siemens Televison & Video Experts
kj henriksen
kj henriksen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fujitsu Siemens Televison and Video Expert? Answer questions, earn points and help others
