The water isn't draining and washer isn't spinning
  • 59 Answers
It will not spin if the water doesn't drain.
check the pump is ok and not blocked. check the filter if it has one, they are normally at the bottom on the front.
mind for water coming out when you remove either.
Posted on Mar 16, 2011
SOURCE: Washer won't spin or drain
I took the easy advice first. One guest said it was the lid switch. So I opened the lid and put a clothespin in the hole and then leaned the lid on it and guess what??? It began to drain and spin perfectly! PHEW... that saved me some time and money till I can get the switch replaced. THANK YOU "guest" from August 11th!!!
Posted on Aug 28, 2008
  • 112 Answers
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
If the unit is still agitating as it is supposed to, this is usually due to a faulty lid switch.
Posted on Oct 25, 2008
SOURCE: water does not drain out from my washer
I have determined one of the reasons ( I feel this is the primary reason) why many BOSCH washing machines will not drain the water, Bosch uses the same drain pump in many of their 500-800 series washing machines, part number 436440. The drain pump is a electrical controlled magnetic driven pump. Simply a electrical current produces an electrical field which a magnet rotates, spinning the pump blades. I have determined that the internal seal on the pump part is allowing water to leak into the magnet area of the pump. This is causing corrosion, and water build up around the magnet, interfering with the magnetic field. How I came to this conclusion. After removing the end of the pump, and allowing the water to drain out, drying out the pump, the pump will work as advertised. But of course the pump cannot be used in this condition. A new pump is required. To determine this yourself, if the machine is not under warranty (good luck getting service). Unplug machine, remove back panel, unplug the drain pump, remove drain pump (separating the drain pump from the large plastic holder, there are three screws holding it to the housing). You can shake the pump, and if water comes out of it this is most likely the problem. Now hook the pump back up to its electrical feed, and place it on a rubber sheet. Set the machine to drain, if the pump attempts to spin then stops, or hums this is the problem.
Posted on Nov 10, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
My thin twin wont drain. Checked drain pump and it was clear. When i got all the water out it would spin. It will fill, agitate and spin(as long as there is no water)
The basket drive and or clutch need replacing, as long as their isn't the added weight of the water it spins yet add 250 pounds of water weight its slipping
Aug 03, 2011 | Whirlpool LTE6234D Top Load Stacked...
Won't spin and drain
Hello.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,
Good luck,i hope this helps
Gene
Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle not working
When you say the spin cycle is not working do you mean that nothing works in the spin cycle. For example: Does the drum move or does it move and but the water isn't drained out?
Jun 19, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washing machine isn't getting rid of all the water during the last spin cycle. The clothes are still very wet when it is done. I run the spin cycle more and it only rids a little water from the...
Behind the washer is a plastic hose that enter the drain.Make sure that nothing is pinching it closed.You can also use drain cleaner in the drain but not in the machine.
May 12, 2011 | Washing Machines
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
