Question about Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White
Our Maytag mfi2569vew has a terribly bad odor. I have cleaned everything out and cleaned the inside, the outside, the back, under the frig, taken the lower back off looked for a mouse, changed the filter and cannot find out where the odor is coming from. Do you have any idea what it could be.
  • 37 Answers
SOURCE: fridge has an odor
steve125
You can remove the acess panel from the back,the grill from the front, even pull out the drip pan from underneath.(small socket or nutdriver is all you need) Flood the area with light, (Unplug the unit first) and I bet you will find the culprit up under there somewhere.
good luck
handiman518
Posted on Jan 17, 2008
xMadx
  • 64 Answers
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Posted on Feb 04, 2008
CRTN
  • 716 Answers
SOURCE: terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Posted on Jan 05, 2009
  • 2920 Answers
SOURCE: MAYTAG FRIG SMELLS LIKE A DEAD ANIMAL!!
use bleach straight bleach to clean it it will usually kill any odors coming from a refrigerator clean it both inside and out
Posted on Jan 24, 2009
Fixe_You
  • 1800 Answers
SOURCE: bad smell
clean it with baking soda hot water and hair dryer
Posted on Feb 27, 2009
My older KA Ref Model KTRP20K & M is giving off a strong odor similar to iodine. Very strong in AM but can still smell it in PM. I've checked for spoilage and nothing there. Any thoughts? Is it time...
since it is working ok . i am wondering if you dont have mold growing in the drip pan ... condensation from inside the refrigerator goes down a small tube in the back bottom of the frig ... that tube goes to a pan under the refrigerator and normally the water just evaporates .. if there is a lot of condensate from the frig then the pan may stay wet long enough for mold to get established ... a large amount of condensate from the frig usually indicates a leaky seal around the door .. or a door that doesnt close completely .. you might want to clean everything under the frig including any fans, coils and that pan (unplug first) ... now this all assumes that the smell is coming from the outside not inside the refrigerator .. if the smell is inside then you may have to defrost and clean the evaporator (the coils inside the freezer (somtimes also in the refrigerator) ... there are some kinds of mold that actually grow in that cold environment .. some hot soapy water with a little bleach usually does the job .. or if you have one, a steam cleaner, those do great .. it allows you to get down in the little places and clean everything ... make sure the frig is at room temp first so plastic doesnt crack ..
the refrigerant r22 or r134a have very little smell so even if you had a leak it wouldnt smell strong .. a few refrigerators use ammonia and that would have a distinctive smell easily recognized if there was a leak .
Nov 22, 2009 | Cell Phones
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Drain has a terrible odor. Tide cleaner cleaned
Try Baking Soda down the drain. It's a very good odor absorber.
Aug 16, 2009 | Plumbing
Refrigerator Odor
sounds like fungus in the drain tube
unplug fridge p\and pour some bleach in the freezer
it stinks but it will kill the smell
after 10 min or so take fridge to patio and hose her down water will not hurt the fridge it will however clear the drain lines
and it might be a good time to clean the coils and the colection tray under the back of the fridg any way
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Terrible odor from bottom front of fridge
The milk probably is gone, but there may be something in your coils. Inspect from front at the bottom, behind toe kick trim or from the back by removeing the access panel on the lower back of the frig. Coil cleaning should be done with the frig unplugged, vacuum out the dust and with a small brush resembling a bottle brush but smaller. clean between the coils. Don't force the brush. Twisting with light pressure will work just fine.
Jul 09, 2009 | Refrigerators
Bad smell
Feb 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White Logo
26 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
