Question about Brother SX-4000 Typewriter
Just recently, our typewriter ribbon ran out and we ordered a new. It arrived and it works fine. However, the correction tape that we already had installed no longer "corrects." It rotates from one spool to the other; the tape moves up and down; and we have tried using both sides of the correction tape. Nothing seems to work. What are we doing wrong? Can you help us?
  • Brother Master
  • 3,594 Answers
The ribbon you got is either very old or it is a non correctable one. The knob should be yellow or orange. The other possibility is that the nlift off is installed wrong the dull side should be towards the paper.
DickyO
Posted on Mar 16, 2011
I changed the correction tape on our IBM wheelwriter 3 and it doesn't seem to be lifting the error. Any advise? The correction tape is not old and I had already tried moving it a couple of inches but it...
You may have a very old correction tape or ribbon, a non correctable ribbon or it isn't properly installed
Go to LEXMARK.COM for a downloadable manual.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 3 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Smith Corona SL575 typewriter no longer does corrections.
Be sure that the correction tape is a dry type general ribbon # T355 or equivelent.
DickyO
Mar 17, 2009 | Smith Corona Office Equipment & Supplies
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Correction tape not working
The ribbons and lift off tapes both get old and change composition, get a fresh ribbon and L/O tape then try it.
DickyO
Mar 27, 2008 | Lexmark Wheelwriter 1500 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother SX-4000 Typewriter Logo
67 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
