Question about Health & Beauty
I have a HP8204B Pride battery charger 24vdc 5a 230vac, the wire to the end connector (3 pin with 2 of the pins bridged) has come away and i don't know which wire (one black, one red) to solder to which pin. the charger is for a wheelchair
  • 280 Answers
The red wire is positive and is soldered to pin 1. You can see the 1 on the pin (non solder side) of the plug housing or on the solder side as a raised stamp 1.
The black wire is soldered to the negative pin 2. Two of the pins are bridged to inhibit the power chair operation when the charger is plugged in. Hope this helps.
Posted on Mar 18, 2011
  • psychoboxing Jul 16, 2011
    thank you this is what i needed to know
I HAVE A HP8204B CHARGER 24VDC/5A...
15/230VAC INPUT...HOW MANEY AMPS DOES THIS THING DRAW TO RUN THE CHARGER???
Posted on May 01, 2011
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
I accidently got my battery charger Model #HP8204B 24VDC/4A wet I have replaced the internal fuse several times only to have it blow again and again?
The water caused a short and burnt out wires. Those wires are creating a dead short to earth. You need a new charger and the knowledge not to let it get wet again.
Sep 29, 2016 | Health & Beauty
Can the batteries or my charger be bad on my Pride Jazzy 1113 ATS?
The MK batteries are far superior to Interstate batteries overall.
You can load test the batteries to see if they are working properly with a load tester. Your can test the charger output to the batteries with a digital voltmeter connected to the batteries with the charger plugged in. These 2 tests take less than 10 minutes and can be done at a local auto or scooter shop for nominal expense.
Make sure the charger and battery connections are tight and free of corrosion. On the VSI of the Jazzy 1113 there is a notorious problem with 8 pin connector and 3 pin molex at the back. You can clean these connectors but a complete electrical rebuild of the pins and receptacles is sometimes required if significant corrosion has set in. Try spraying electrical cleaner and use green Scotchbrite to clean the metal tabs on the 8 pin connector. Make sure the 3 pin molex sits in the receptacle and is making good contact.
Hope this helps.
Jul 22, 2014 | Pride Mobility Products Jazzy 1113 ATS
Charging schematic for pride scooter
red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
Dec 29, 2013 | Pride Rally 3 Wheel Scooter
Charger not working fan not stay on and yellow light
You have the 4-amp charger version. If you have the U1 batteries on your Pride you can replace the charger with a 3-amp version after you have your batteries load tested and tested for internal resistance. Verify batteries are good and "finishing voltage" after charging is proper. (14.4volts per battery)
Nov 09, 2013 | Pride Health & Beauty
What fuse do i need for a 24v battery charger / pride hp8204b
Try T4ah That is what CTM uses for its 24V 5A CHARGERS. Good luck.
Jun 25, 2012 | Health & Beauty
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Pride Jet 2 power chair with with 3 red and 3 yellow lights flashing. Batteries checked ok under load, all connections have been checked. I moved the chair and it would not move again. Just that quick.
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
Health & Beauty Logo
1,106 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
