Question about HP 310 Color Copier
I am disappointed that I cannot print an 8 1/2 x 11 photo on my HP310a even though the photo on the box it came in shows just that! Do I need to by an additional paper tray? Besides the photo tray is a pain if you take it out, you have to turn the printer practically upside down to get it back into the slots. Any suggestions?
SOURCE: Mac Leopard OS: Can't print from photo tray
Here's the trick. It took me an hour to figure this puzzle out myself. DO NOT select the Print icon at the bottom of iPhoto. Do NOT select Print from the File menu. DO select EXPORT from the File menu. Select the HP Photosmart Mac tab Select HP Photosmart Print.app from the app selector. Click the Export button. HP Photosmart Print.app will load with a new print dialog box. Make all necessary selections. This is where you can select the Photo Tray as the tray for the printer to take paper from. This solved MY problem! Let us know if this helps you!
Randy
Posted on May 23, 2008
  • 6 Answers
SOURCE: Photo Tray Problem Error Messege Prevents Printing
kknjhinklo
Posted on May 28, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Posted on Oct 13, 2009
SOURCE: I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Posted on Nov 27, 2009
Only printing 1/2 the image of the selected photo, I have tried changing the printer cartridge but still only prints 1/2 the selected image, any ideas why this is happening?
I am not familiar with that particular printer, but it could be as simple as making sure you have the entire picture selected..but it sounds more like the cartridge is either clogged or there is a setting that needs changed...try aligning the cartridge(s) and printing a test page. (that part is usually under a maintenance or troubleshooting type section) if that turns out fine, then there may be a setting thats off...look at your print settings...you may have a separate section just for printing photos...even if you don't, look at your page setup.. look specifically at the margin settings...that might be where the problem lies..you can always play with the margin settings- i would recommend saving them under a custom setting if you want to keep them, instead of default though...that way you have your regular settings for general printing... and do a "print preview"...that might be a good idea anyway, so you wont have to waste ink and paper trying to get your stuff to turn out how you want it (plus that will show you if margins are set right)...for that, there should be a checkmark box you can select to always do print previews...
also, look to see if you have a selection or checkmark box that says "fit to page" or where you can select how many copies you can print per page..this can be used for everyday printing, as well as for photos...
you may even see a spot where you can select the size of photo to print...usually you can pick to print "wallet size or 4x6, ete." and how many to print on a single page...maybe even multiple sizes per page...these are several options for you to look at...hope it helps :)
Jul 30, 2015 | Samsung SPP-2040 Digital Photo Printer...
My black and white photos will only print out in sepia. I have plenty of ink in the Cartridges of my MP610. Please help?
Two possibilities come to mind:
  1. There is a function in many printers that lets you print in the single colour of your choice. Check every tab and every "advanced..." dialog box you get when you are about to print. Then go to the printer's properties in the control panel and check whether there's anything like that
  2. Many printers let you print black with black ink, OR alternatively make black by mixing the other three colours CMY. Look for that setting in the same places and deactivate it
Feb 27, 2013 | Canon MP610 Photo All-In-One Printer
Why am I still getting banding even though test prints are ok.
Sounds like you've picked up some dried ink on the print head or ink holder. I would suggest removing all the ink cartridges and the ink holder (see directions from Canon) and clean the bottom with rubbing alcohol and a Q-Tip or cotton cloth. DON'T use paper towel, it leaves lint. Check the rollers also to make sure they don;t have ink residue on them. Be cautious when working inside your printer.
Jan 24, 2010 | Canon i9100 InkJet Photo Printer
Showing out of paper even though paoer loaded
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 10, 2009 | HP DeskJet 3940 InkJet Photo Printer
Can't print on home network
Well an unisall and reinstall of the printer drivers on the network would definately solve your concern.If you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
Jan 20, 2009 | HP Photosmart D7360 All-In-One InkJet...
Epson 1290s printer
Have you set the paper size correctly? If you try to print on A4 and the printer is set to "letter" - which is the default for a number of printers. Also check that "Borderless" is selected in the driver.
Steve
www.yourhandinmine.co.uk
Aug 29, 2008 | Epson Stylus Photo 1290S InkJet Printer
Lexmark Z53 prints photos on 'normal' but enlongates image on 'best'
I'm getting around the problem by using Windows or Nero print options to get the photo as near to the size I need. It would be good if I could print photo's from Photo studio though much simpler and less time consuming.
May 23, 2008 | Lexmark Z53 Color InkJet Printer
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
HP 310 Color Copier Logo
13 people viewed this question
Seeker5211
Seeker5211
