Question about Kenmore Elite 45986 Front Load Washer
Where does the detergent go and where do i put the fabric softerner? I am using a Kenmore Elite front load washer. thanks, Adriana
    Brigadier General:
  • 6,277 Answers
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Cheers,
John C
Posted on Mar 16, 2011
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
I purchased the Kenmore Elite washer approximately five years ago. I have had no problems with it operating. However, since purchasing this washer I have ruined almost everything white I owned and avoid...
There has been many reports of complaints regarding this problem and it was found out that the gray spots on white clothing are caused by the fabric softener. The Kenmore Elite is a "highly efficient" machine that it uses very minimal amount water when washing and rinsing. The minimal use of water results in the fabric softener not being diluted completely and eventually makes gray spots on white clothing. The ridiculous solution to this problem, as Sears "advised" is not using fabric softener for white clothing. But you may also try putting the fabric softener in a small plastic bowl just enough to hold it and place it inside the machine prior to the final rinse. Using only the suggested amount of detergent and avoiding the use of detergent powder with speckles reduces the possibility spot occurrences in your while clothing.
Aug 27, 2010 | Kenmore Elite 45986 Front Load Washer
My sister pours a lot of liquid softener into our Kenmore Elite front load dispenser. I said to only use 1/4 cup as recommended. Will using too much fabric softener cause problems?
YES!! This machine uses an average of 14 gallons of water per load as compared to 40 gallons for a top load!! Less water means less detergents!! Excess detergent and softener can create build up withing the machine that will cause unpleasant odors and eventually rear bearing failure.
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
Hi, I'm house sitting for a friend and he has a kenmore elite washing machine. Which slot do i put the liquid clothing detergent in? softener? or
The LEFT slot is for detergent. Do not overfill, or you may experience a "SUDS" error. It is recommended that only HE detergent is used. The RIGHT front slot is where you put the fabric softener. Again, only fill to the fill line.
These washers are engineered to use very little water, so you only need a little detergent. If you have questions, please let me know. I hope this helps you.
Sep 03, 2009 | Kenmore Elite 45986 Front Load Washer
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
How to use liquid detergent and powered bleach?
You should be using a HE liquid detergent. Does you machine have a dispenser for that? The detergent should go in that dispenser. You can put the powdered bleach right into the drum before you load the clothes. I am assuming this is an all fabric bleach.
Happy Clean Clothes!
Aug 18, 2008 | Kenmore Elite 45986 Front Load Washer
HE washing machine
As you look at your dispenser. The Left compartment is for Detergent. The Right Front compartment is for the Fabric Softener Liquid. The Right Rear compartment is for Chlorine Bleach.
Jul 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Load Washer
Remove the dipenser and feel down inside the hole. You will probably feel a detergent build up in the cavity. If so clean this out and rinse with hot water. This problem is becoming more common since people are washing more in cold water to save electricty. Some detergents and fabric softeners will not disolve in cold and it "gums" up the works. Post back to let me know what you find.
Oct 08, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
117 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
