Question about Universal Kreepy Krauly In-Ground Pool Cleaner
My kreepy krauly's hose blocks entrance to the skimmer causing the pump to lose prime
  • 640 Answers
It sounds like you might need to use the eyeball diverter to redirect the pool cleaners water flow and keep the hose from blocking the skimmer. Here is a copy of the users manual. Take a look at the section that describes this and see if that corrects the problem.
http://www.backyardcitypools.com/images/pentair/kreepy_krauly_manual1.pdf
Posted on Mar 23, 2011
What should be the length of the hose for my KK for a9.2metre pool, kidney shape, with the skimmer box centred on the side of the pool
Just long enough to reach all wall and floor surface.
with equipment turned off, put one end of the hose into the suction port, then, holding the other end of an estimated proper length, walk around the pool all the way around, making sure that there is at least one extra length going beyond the pool wall.
It's because you mentioned the location of the skimmer, that makes each pool different. If the skimmer is located on an end, naturally you will need additional and longer hose length.But with the skimmer located in the center of the pool, the overall length of those will be much shorter, than the example above.
Good luck
Feb 28, 2015 | Universal Kreepy Krauly In-Ground Pool...
Kreepy Krauly has very little suction thru head but plenty thru hose
most all pool cleaners generate there motion with a thing called a venturi ! thats inside it usually moves a small propeller from the action of water being sucked hard thru the hose , on most the path to this "propeller" is different than that of pool debris , i suspect this alt path is part ways blocked , a simple way to clear is to connect garden hose to suction port of cleaner and force water Back in other direction other than that sometimes dissasembly is need to lube and clean hidden ports inside
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Skimmer hose collapsing
There is variable suction valve that attaches to the vacuum port that I believe is missing that keeps this from happening, attach it an it wont happen again.
Jun 01, 2013 | Hayward Pool & Spa
Kreepy kraully not cleaning complete pool
If the pool hose has been connected to the Kreepy Krauly in the one position for a long time, the pool hose gets set is a position so the kreepy Krauly travels ith same path all the time. Try rotating the pool hose 90 degrees and or change the angle of the hose connector in the skimmer box.
Mar 07, 2012 | Pentair Kreepy Krauly Inground Automatic...
Kreepy krauley does not clean properly
Try adjusting the suction and or the angle of the hose in the skimmer box.
Feb 27, 2012 | Universal Kreepy Krauly In-Ground Pool...
Kreepy krauly hose collapses
This is always caused by a clogged skimmer head.
Feb 02, 2012 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly doesnt want to ****
With these pool cleaners, your problem if going to be an air leak. You need to find and correct the air leak that is causing the pump to lose its prime. Check the hose to ensure that there are no leaks. Check your vacuum connection. It should be submerged so no air enters the system. Check your pump basket lid for looseness, cracks, and worn or missing o-rings.
Aug 01, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hose collapses, single skimmer intake, worked before installing new pump. Pool guy says with only one pump input, no use of jandy valve is possible. Need to know if there is a Kreapy Krauly 'plate' or...
If you go a new pump and the cleaner stopped working, chances are that your automatic pool cleaner is not compatible with your pump. Your pump must be able to produce at least 25 gallons of water per minute to work with this cleaner.
Jun 17, 2010 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly is working at half speed, any ideas? I've checked the tubing, no visible leaks, flapper works. Seems to pull air into the filter even after tubing is full of water. Both baskets clean.
Are you using a skimmer plate with the regulator valve or is connected direct to wall? Do you have a valve near pump that allows you to select skimmer or main drain or other input port? If so, select only skimmer. What is the pressure on your filter? Filter may need to be backwashed.
Aug 05, 2009 | Universal Kreepy Krauly In-Ground Pool...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
108 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
