Question about Maytag Refrigerators
Maytag model msd2142arw, side by side fridge. freezer works great, maybe too good, i keep hard liquor in the freezer and it froze the southern comfort, fridge does't work. this has happened before, a few years ago and i call a repairman. he said something froze up and the fridge has worked fine ever since.
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
SOURCE: Maytag fridge w/bottom freezer
since no one is answering I do have some knowledge, check the defrost thermostat, which puts the unit in defrost mode to melt small frost build-ups, also check seal on your door to make sure you are not getting warm air leaking into freezer, good luck
Posted on Mar 13, 2008
SOURCE: Maytag refrigerator Model MZD2766GEW
You need a new Adaptive Control - part number 61005988.
Posted on Sep 29, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 254 Answers
SOURCE: freezer has bad smell, cleaned entire fridge and
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Posted on Mar 31, 2009
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Fridge stopped working/ freezer still works great?
the freezer works ok..this is where the cooling unit is..so, if the freezer works ..its not blowing or allowing air to flow into fresh food area..if its missed its defrost..it will not allow air to go into fresh food area and you need to remove panel and defrost coils ..or see if blower is working...check for bad heater or defrost thermostat or what controls defrost ie timer or board
May 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
Maytag freezer keeps thawing food
I am no pro on these but it sounds like your defrost heating coils are coming on to often. You may want to check them. Aslo just for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 20, 2010 | Freezers
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Freezer fine- fridge temp is 51 degrees
I got the same problem. For some reason in the freezer part on the back wall there is a condensor and it keeps on getting all iced up and then there is not enough air pressure for the fan to circulate cold air to you fridge part. I took mine all apart used a hair dryer to thaw out everything which took out about 1 gallon of water from the hose in the bottom back of fridge. It fixed the problem for about 4 days and then froze up again, There must be some type of tempature sensor or automatic defroster not working like it shoud.Does anybody know? Help me too?
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Maytag MSD2142ARW side by side and it has been steadily gettingwarmer on the fridge side. The freezer appears to be cooling fine and I know the fridge gets its cool from the freezer side. The fan...
HI, your Temperature Control Module has failed. it controls the air flow and vent(damper) action. replacing the temp control mod will fix this issue you are having at this time.
Jun 10, 2009 | Maytag Freezers
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Refrigerators Logo
115 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
