It keeps saying that Toner is empty and to replace it i replace it and it keeps saying the same thing what should i do
    Problem Solver:
  • 10 Answers
Try updating the firmware
Posted on Mar 16, 2011
  • tes5884 Mar 16, 2011
    also check the manufacturers site for more info
Why does toner waste bottle keep indicating it needs to be replaced?
But you did not clean the clear section of it still has toner blocking the clear section, I am assuming since no Model number or make was given Correct thing to do is replace the waste toner box
Jan 21, 2016 | Office Equipment & Supplies
Tip
Printer stops printing before toner cartridge is empty.
You have to keep replacing your toner cartridge before it is empty. It could be anywhere from 1/4 to 3/4 full and the printer says that it is empty and needs to be replaced. <br /> <br /> This happens because of the sensing mechanism used in toner level sensing system. For the printer to know when the cartridge needs to be replaced manufacturers generally use a simple, and generally reliable system of infared emitters and sensors. An infared beam is shined through the toner cartridge from one side and a receptor senses the beam on the opposite side. As long as the beam can't shine through the cartridge all is fine and the printer thinks that the cartridge has toner. When the beam is detected by the sensor the printer thinks the cartridge is getting empty. All you need to do for a sensitive sensor is to block the path. The only thing you will lose is the ability to be warned when the toner is getting near empty. As long as you have a new toner cartridge on hand this should be of no consequence.<br /> <br /> To defeat the sensor remove the toner cartridge and look at both ends. There should be a clear window on each end for an infared beam to shine through. When full of toner the beam is blocked. If you have a sensitive sensor which can detect the beam before the toner is gone you will get a warning before the toner is completely gone. <br /> <br /> Carefully place a small piece of opaque tape, (masking or electrical tape) across the window to block the beam. Make sure that the tape is secure and will not fall off inside the printer. This should solve your problem and allow your printer to print until the toner is completely empty.<br /> <br /> Thanks for using FixYa and for the great rating.<br /> <br /> hardrocko
on Jun 07, 2011 | Office Equipment & Supplies
Add toner problem
toner is empty replace new toner
Jul 14, 2014 | Ricoh Aficio Mp2500 Mp2000 Mp1600 3030...
Add black toner but still empty
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Jun 03, 2014 | Ricoh Aficio SP C820DN Laser Printer
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
Emty error with new toner. Oki B410
What a usless "solution"...Do you have something that can accually work?
There is a procedure that will solve this issue. I have a new toner inserted and it keeps crying that the toner is empty...I have taken in out and put it back in, Now how do I reset the **** thing?
Mar 06, 2010 | Oki Electric Industry B410D Laser 30PPM...
Put in second toner and machine is still saying toner empty
If you are using refilled cartridges those errors are common, Samsung has an eeprom on the cartridge keeping track of usage and you need a new chip from the refillers. If you are using OEM cartridges you need to clean the contacts inside the machine that the cartridge connects to and wipe the contacts on the cartridge before installing, Otherwise a shop repair for the CRUM circuits.
Sep 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Replaced Black TOner but still says it is empty
One way you could reset the toner is using the service mode.
Is this printer a 2300w ? If so, open the front door of the printer, turn on and hold down the cancel button for at least 20 seconds, that resets all the counters to factory defaults. The only problem is, that it will set all the toners to 100% and standard capacity, but you can change that in the software. One good thing is, it sets the OPC drum,
Fuser unit, transfer belt, everything to 100%
Delboy
Jan 26, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Low toner/toner empty
Toner cartridges have more then just "toner ink" they also have developer and sometimes a chip that says how many times the cartridge has been used.
Also some refill places can be a bit dodgy so I know it might not seem like the best thing right now but try buying a real replacement cartridge and if that doesn't do it beg and plead to return it saying it was the wrong model.
If it does fix it then you might have a bad cartridge that either has the "chip" or the cartridge itself is simply worn out and in need of developer as well.
Apr 16, 2008 | Brother MFC-8440 All-In-One Laser Printer
15 people viewed this question
jasbo
jasbo
