Question about Neff H5430 Convection Microwave Oven
The door catch has ceased to function which I assume is spring loaded but no longer has any tension. Also there does not appear to be any obvious way of accessing the workings of the catch.
  • lpsymmons Mar 16, 2011
    Daniel not wishing to be rude but all you have done is to state the obvious as I know it is not working otherwise I would not have prompted the problem so how do I replace it and if it is the door switch what is the way forward?
  • 4,323 Answers
Hi
If it is not working then it should be replaced. The issue can also be with the door switch that is not working and so wont allow the door to function in right way. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 16, 2011
  • Daniel Scott
    Daniel Scott Mar 16, 2011
    You are
    right...Sorry I thought you were just confirming about the part that you want
    to replace....Use your ohmmeter to test your
    switch for continuity. Begin by setting your ohmmeter to measure resistance at
    a scale of Rx1. If you are using an analog meter, touch the metal tips of the
    test leads together and zero your ohmmeter by adjusting the thumbwheel in the
    front of the meter until the needle reads '0' on the scale.
    Hope this
    Daniel
    You are right...Sorry I thought you were just confirming about the part that you want to replace....Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of Rx1. If you are using an analog meter, touch the metal tips of the test leads together and zero your ohmmeter by adjusting the thumbwheel in the front of the meter until the needle reads '0' on the scale. Hope this helps...please post back for further assistance.
    Daniel
Door won't latch. Can it be fixed
Yes you will need to dismantle the door by undoing the inside screws and taking the glass panel off then replace the catch - its usually on a spring load - may be just the spring thats had it.
May 12, 2014 | Microwave Ovens
Door doesn't latch
Can you move the latch in the door? This is spring loaded, maybe the spring is broken
Mar 09, 2013 | Maytag MMV1153A Microwave Oven
My boyfiend slammed the door shut and it has not worked since then
The door latch (on the door) or the door catch (on the oven) have most likely broken. The oven will not operate if the door is open or if it is not correctly closed.
Check the door latch. On most microwave ovens there will be one or two prongs. Make sure that they're not broken and that if neither of them is loose. Often one or both are designed to move upwards against spring pressure so if they move loosely with no spring pressure then the door must be dismantled to find out why. Often it's a broken spring anchor and sometimes it can be repaired, but the official fix is to replace the entire door assembly.
If the latch seems fine then it's almost certainly the door catch unit which must be repaired or replaced. They're not officially repairable, but sometimes all that has actually broken is a cheap and easily obtainable microswitch. If the catch has actually broken then there is no point in gluing it together as it won't hold. If the door catch assembly looks fine and the microswitch appears to be operable then use a continuity meter on the switch to confirm correct electrical function as the switch is pressed and released.
If that fails, then look for any fuses on the circuit board, the filament inside can break if they're subjected to too much physical impact. Test and replace any failed ones, but it's vital to use the correct type, the casing will indicate whether they're slow blow or fast blow fuses. These properties are independent of the voltage and current rating and simply regulate how quickly or slowly a fuse will fail if the limits are exceeeded. using a slow blow in the place of a fast blow is dangerous, but using a fast blow or a regular fuse where a slow blow goes will just mean that the fuse blows more often or even immediately in normal use, often when the door is opened.
If you need any spare parts then you'll have to find suppliers yourself, sorry. I don't know which country/state you're in and I'm based in London, England, where Emerson is not a known brand.
I hope that my answer helps you to either repair your oven or to decide whether to replace it. Please take a moment to rate my reply.
Sep 23, 2010 | Emerson Black Microwave Oven
Replace sping in door model r 1611
The spring is probably OK, but tab it mounts on may have broken. To remove the door, pry out the little cover (~1.5 in by 1 in) on the inside of the door by the upper hinge. Then you can lift the entire door off the hinges (with the door open). Then you have to pry the inner plastic fascia (faces the cooking cavity) that surrounds the glass. Once that is off, you can see where the spring is, or was. My tab had broken, but I was able to mount a small bolt thru the endplate of the door (so it doesn't show when the door is closed) which I could mount the spring on it. There isn't a lot of clearance on the outside, so a low profile head on the bolt is better; otherwise, the head will catch on the edge of the control panel as you try to close it. I put 2 nuts on the inside, with locktight, and put the "hook" of the spring around the bolt in between them. I will admit, I had to drill 3 holes before I got an acceptable amount of tension on the spring (I kept having too MUCH tension). For some reason, putting the bolt approx where I thought the tab had been resulted in too much tension. I suppose I could have stretched the spring some instead of relocating the hole and bolt. Push the fascia back into place, remount the door on the hinge, and replace the little cover. Hopefully the door will line up OK, the latch will catch and release as it should, and the interlock will be released as it should be when the door is securely closed (and interior light goes out). One other caveat, I am not a professional, and the door does need to "seal" or I guess all those evil little microwaves can escape and emulsify your brain, or whatever would happen. I will not be held liable if there is leakage.
Apr 23, 2009 | Sharp R-1610 Microwave Oven
Door catch not working on whirlpool MH1150xm
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Feb 02, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave door does not latch; oven does not work
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Dec 22, 2008 | Sharp R-1405 / R-140 Microwave Oven
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
Door latches will not close onmy Panasonic Dimensions 4 Microwave NNCT766MBPQ.They appear loose as if a spring has broken.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Panasonic Microwave Ovens
The door catch on my Bosch 8656 built in microwave has failed after only two years use. The catch itself is not broken but the spring mechanism inside the door no longer pushes the catch into the closed...
Yes, for some brands and models.
Sep 15, 2008 | Bosch Microwave Ovens
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
Neff H5430 Convection Microwave Oven Logo
82 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
