Question about Sony Ericsson T707 Cell Phone
My sony errison T707 can't be charged.. charger is ok for another mobile. no light or sign at all the connection part is fine...never into water. just not able to charge the phone....
SOURCE: phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Posted on Aug 28, 2008
SOURCE: w810i not charging
basicly there are 3 pins on the top of your phone (take the battry out and you shall see them on the far end) get a pair of tweezers and push the clips in and hold for a while ... slot your battrey back in and put it in charge it should work :)
Posted on Oct 03, 2008
taran_2005
  • 10515 Answers
SOURCE: Not able to charge the battery
As per Sony, if you are getting this message, it's a concern.
This message usually appears, if you are using a Battery other than Sony's.Make sure you are using Original Sony's charger. Try to use some other Charger and Battery.
If problem persists, you need to send the unit for repair. More likely, it's a firmware issue. I have hardly seen any Charge / Battery issue.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 13, 2009
AldRezaine
  • 995 Answers
SOURCE: my sony ericsson w995 does not charge when i try
That only means that you got battery problem of your phone. Replace the phone battery with a new one. If your old sony ericson phone battery can be fit to your w995 then you can try to use it.
Hope this could help..
Posted on Mar 28, 2010
SOURCE: Sony Ericcson t707 battery charge
the problem is the actual genuine sony charging cable not the phone. it's a bad connection where it plugs into the phone. this also happens with the original sony usb cable.
I believe that the pins are a fraction too short and therefore do not make a solid firm connection on the gold pins. That's why sometimes when you wiggle it around, or hold the cable in a certain position it works well.
The original sony cables are the problem!!!!!!!!!!
I fixed my sony ericson T707 charging problem and usb cable connection problems by buying a cheap no name charger and usb cable from china on ebay and have never had a charging or usb problem ever again!!!!!!!!!!!!!!!!
Posted on Aug 09, 2010
I have a T707/T707a/T707u and did not get a USB connection to transfer pitures to computer. Is this standard equipment with purchase or do I have to buy one. Also should it fir in the same place as the...
Hello and Welcome to FixYa!
The Phones T707 uses the same DCU-60 series USB data Cable, You should have been given the cable with a new phone. If not, you can purchase it from here.
And yes, the cable is plugged-in the same port, where the charger pin goes.
I hope you will have a clearer picture now.
Concerned, Nooh.
Apr 02, 2011 | Sony Ericsson Cell Phones
Why won't my sony ericsson t707 charge when the charger is plugged in???
first check whether your charger is ok, if it is working on another mobile, look for corrossion on the charging connector of your phone, if you see it corroded or clogged, power off your handset , remove battery and then clean the contacts with a pin or a small blade.
reinsert battery and try charging.
it should be working now.in a rare case if on connecting charger there is red light blinking and your set is not turning on you have a software crash and need to be updated at a service center.
regards
please comment
Jan 01, 2011 | Sony Ericsson T707 Cell Phone
I want an software to connect internet to my computer through cell phone F305 sony errison
you can use sony ericsson PC suit to connect internet to computer through cell phone F305 sony ericsson.
NOTE:Your mobile should be connected to computer via USB cable.
May 15, 2010 | Sony Ericsson F305 White +512MB Unlocked...
It wont turn or charhe at all
most of sony ericsson mobile create only problem through charging battery. sorry to insult your mobile.
Tenzin
May 02, 2010 | Sony Ericsson T707 Cell Phone
has the battery been charged before the battery was flat? if yes this has cooked the battery and now needs replacing
Apr 10, 2010 | Sony Ericsson T707 Cell Phone
I need to unlock a sony ericsson t707 mobile phone locked to the network 3
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
Jan 04, 2010 | Sony Ericsson T707 Cell Phone
K550i charging problem
in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
Phone won't charge
check charger pins and charger socket and its contacts and the fue in the board. if anyone fails in this charger wont work.
Feb 06, 2009 | Sony Ericsson W660i Mobile Phone
I have a sony errison 850i mobile fone and wanted to know can i block certain numbers from ringing me
sory your language i cant folw it.
kindly as US ENGLISH. PLEASE
Good luck and kind regards. Thank you for using FixYa.V
Feb 22, 2008 | Sony Part 996804671 Service Manual for...
Sony Ericsson T707 Cell Phone Logo
109 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
