Question about Nokia BH505 Bluetooth Stereo Headset
Nokia BH505 problem. The power button no longer
Nokia BH505 problem. The power button no longer operates on the headset and is permanently switched off so I am unable to pair the device. The headset does take a charge & was working adequately previously. This is the second headset that has failed in this way. Any thoughts anybody?
2 Suggested Answers
  • 9 Answers
SOURCE: My BH505 Bluetooth Headset cannot
http://blog.thepcmechanic.org/?p=74
Posted on Aug 17, 2011
Can we replace the battery ?
Go here: http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-505_APAC_UG_en.pdf
Apr 02, 2015 | Nokia Bh505 Stereo Bluetooth Headset -...
Restriction code for Nokia 6020
Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
Mar 16, 2014 | Nokia Handsfree For 6020, 6101, 6102...
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
Nokia BH505 open up
put your nail between the white and the black part of the cover (near the upside of the volume button) and open it. dont loose the little silver button and keep in mind how it was placed. That makes it easier when you want to reassemble your headphone again. when you have opened it you will see a lot of little wires connected to a white plug. take the plug out of the connector by using a small screwdriver or something else to push the plug out of the connector. or simply pull by the wires, but take care not to brake them
Jul 23, 2012 | Nokia BH505 Bluetooth Stereo Headset
Hi, guys. I recently bought a Nokia BH-505 bluetooth headset. I succesfully connected it to the phone (s Galaxy S) and used all its features but i cant connect it to the pc. The pcc just doesnt see it. It...
Hi Bogdy_3003,
I see that you are having issue with your BT Nokia headset.
You mentioned that you are having issues connecting it to our PC.
You need to make sure that the Bluetooth settings on the computer is set to allow other devices to detect the computer to be able to get your Bluetooth Nokia headset working with your computer.
Look for the Bluetooth icon on the lower right side of the taskbar somewhere near the time then right click on it then select open bluetooth settings, it should open up a window for the Bluetooth on your computer then look for "Allo other devices to detect this computer" and put a check on it, click on Apply or OK, this should make your computer be detected by other BT devices such as your Nokia headset.
I hope this will help.
Have a nice day,
mvincentc
Jun 21, 2011 | Nokia BH505 Bluetooth Stereo Headset
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
How to conect BH-505 to nokia N8 booth are new
can i connect bluetooth headset BH-505n N8 mobile
Feb 10, 2011 | Nokia BH505 Bluetooth Stereo Headset
How to pair nokia bh-104 with iphone
Ok.. you need to do the following:
1. Turn the headset off. 2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices) 3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
May 23, 2010 | Nokia BH-104 Bluetooth Headset
Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
Jan 28, 2008 | Nokia BH-600 Wireless Headset
Nokia BH505 Bluetooth Stereo Headset Logo
75 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
