Question about Acer Aspire 5315 Notebook
Where is the bios/cmos battery located on a aceraspire 5315-2698? I cant get past the password screen.
    Scholar:
  • 150 Answers
The battery in Acer Aspire 5315 is very visible has a blue ring of plastic or rubber around it. follow the leads which are very short and short the circuit. no risk of damage to systemboard)
1. Try to remove cover
2. Find battery on the far right hand of the board
3. Take a small flat screwdriver and contact the two leads from the battery
4. Power it on and power it off to reset the BIOS
5. This should work for passwords
6. Moreover, it resets to default configuration
Please share the results.
Regards,
Anirban Mazumdar
Posted on Mar 16, 2011
  • dfreeman1606 Mar 24, 2011
    Tried that it reset user and supervisor password but not hdd password still can't get in
  • 229 Answers
Visit this site and follow their instructions. Let me know if this was helpful.
http://www.findpassword.net/reset-acer-aspire-3610-bios-password-only-8-steps/
CANT ACCESS BIOS
Remove CMOS battery (Large button battery on the main board). Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on
Jul 06, 2016 | Computers & Internet
How do I unlock laptop screen lock?
Hello, You will have to get a program called password cracker in order to get past this screen.Here is the website for this.
May 17, 2014 | Lenovo ThinkPad T61 Notebook
I 4got my password.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
Sep 20, 2011 | Computers & Internet
Forgot my old password
also
Sep 17, 2011 | Computers & Internet
Hdd ata-password
which operating system and what type of computer?
also
Sep 09, 2011 | Computers & Internet
Password is forgotten. I can get passed the booot up screen. I cant get into the boot menu or setup with out the password. please help
You will have to do a hard cmos clearing which will load your bios back to it default value. 99% of the time if will clear the password. In order to do this, you may have to tear your laptop apart just to get to the cmos battery which is located on your laptop motherboard somewhere. Once you located your cmos battery which is silver/nickel size of a nickel, you need to take this battery out for a few minute and then reinstall it back, then put your laptop toghter and then it will clear the bios and reload to it's default setting.
Jan 13, 2011 | Dell Latitude C640 Notebook
My acer 2490 is asking for a setup password and i dont know what this is i cant get on my computor at all it start of black screen then says writing then tells me to press f2 and when i do i get a light...
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Dec 21, 2010 | Acer TravelMate® 2480-2698 PC Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
Lost bios password
if you are refering to bios password then you have to locate the cmos battery and remove for 5 minutes or so,or clear cmos memory terminal on the motherboard by shorting it, but location of these is tricky, normally around the hard drive bay.
May 02, 2007 | HP Compaq Business NX9110 Notebook
Acer Aspire 5315 Notebook Logo
692 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
