Question about Boss Micro BR Digital Recorder
Hi. I really hope you can help me. No one else have so far! This is my problem: When I connect with USB to my computer my Boss BR900cd hangs, and the only way tp turn it off is by using the main switch. But this has not allways been a problem. Ive done this before without any problem.
  • Boss Master
  • 5,603 Answers
See if unplugging the USB will then allow it to turn off... If it does, likely the USB is backfeeding enough to keep the power circuit alive. It is possible also that the software on the PC needs to close as they may have an interlock that prevents one from dumping power if PC is still connected... Just some thoughts on possible reason for the symptom.
Posted on Mar 16, 2011
Boss br900cd factory defaults re install
Here is the newest updates for it, http://www.bossus.com/gear/productdetails.php?ProductId=718
1. Press [UTILITY].
2. Press CURSOR [ ] [ ] to move the cursor to "INI,"
and press [ENTER].
3. Press PARAMETER CURSOR [ ] [ ] to move the
cursor to "ALL," and press [ENTER].
The confirmation message "Are you sure?" appears in
the display.
4. To continue the initialization, press [ENTER] (YES).
To cancel, press [EXIT] (NO) (or [UTILITY]).
When [ENTER] is pressed, initialization begins.
After the initialization has been completed, you are
returned to the Play screen.
You can perform the same initialization with "INIT
ALL," by holding down INPUT SELECT [GUITAR/
BASS/MIC2], [MIC], and [LINE] while turning the
POWER switch ON, then pressing [ENTER].
Mar 03, 2013 | Roland Boss BR900CD Digital Recording...
It just wont turn on, and i'v tried other power supplies that deffinately work and it still wont. help!
Use the correct PSC power adapter. 9 volts, 1 amp... not sure of the polarity... searched all over for the spec. The unit draws 900ma so you need a 1 amp supply. Most "universal" supplies will not provide enough current. If you have tried the wrong polarity you may have damaged the unit.
Sep 14, 2011 | Roland Boss BR900CD Digital Recording...
My roland br 1600 cd rec.studio is just over a year old.I have 4 songs currently on it (80 gb) and it says HD full.It cant be full ....I cant work because of this error...
Yep... the hard drive is 80GB... so if you have 80GB of songs (not hard to do) it is full. Purge some off to make space. Those must be either long songs or have a lot of high frequency stuff using a lot of data to store them or a lot of tracks per song. For stereo recording two tracks using computer I chew up about 1 GB per hour. If you have armed more tracks this could really jump up... and these units may not be as efficient as the new software PC DAW's. I would recommend purging existing songs to a safe media and then reformatting/initializing the drive in the unit.
Aug 18, 2011 | Roland Boss BR900CD Digital Recording...
Br900cd unable to remain switch on
Check power source or batteries. This unit will go through batteries fairly fast and when low the unit will not stay on. You CANNOT use rechargeable types as they have lower voltage and they quickly fail and shut off. Check the voltage out of the adapter if you are using one..
Apr 06, 2011 | Boss Micro BR Digital Recorder
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
I want to download my songs from my BOSS micro BR 4track but everytime I plug it into my computer it says USB idling... and when I try to download it will not play any of my songs. How do I download?
It sounds like you have not loaded the driver for the device into your computer. While USB will automatically connect to many devices that are common like printers and mice, these special music devices require support software in the computer.
Aug 31, 2010 | Boss Micro BR Digital Recorder
Downloaded version 2 to my br900cd now one of my flashcards that i had several songs on will not load message saying unsupported card
Don't you just hate these incompatibility issues?
Try the VSPLANET.com site where a lot is discussed about the Roland (Boss) recorders.
May 13, 2010 | Boss Micro BR Digital Recorder
Sounds like a version compatibility problem.
Check with the folks over at VSPLANET.com where Roland digital recorders are discussed in the forums.
Mar 22, 2010 | Boss Micro BR Digital Recorder
Boss BR900CD External MIDI
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Dec 02, 2017 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
75 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
